A8 Intake Arms 077-198-327A
#11
LOL! Yeah that place is like a morgue isnt it ? Waiting for that service guy to lop your head off. Thats why this forum is so great.
Ive heard to seafoam actually disintegrates the plastic buts its OK for older engines. Sounds like some have had good success here though.
#12
Things like the inlet manifold have to withstand heat and oil - and it's nasty oil too, vapours that come through the EGR and PCV systems.
So despite the fact that a lot of modern vehicles use polymer manifolds, they are still pretty robust materially.
I think manifold cleaning should be a regular part of engine maintenance, as a clogged up manifold will reduce performance (just ask the FSI owners!). Subaru dealers sell an alternative to Seafoam for those that don't trust it (at least they do down here).
There's also a Nulon product, but you may not be able to get Nulon in the 'states.
#13
The rear pivots (interior rear of manifold) are constantly lubricated by oil vapor from the PCV valve....dripping with oil. The outer pivots (the problem) get no lube EVER...totally dry composite shaft turning in an aluminum bore NOT sealed on the outside (road dirt). I firmly believe that sealed roller/ball bearings here instead would have cured the eventual seizing problem.
#15
Here's a post where a much worse problem was remedied...a good look at the manifold guts >>>
http://forums.quattroworld.com/a8/msgs/181.phtml
#16
Does anyone know a good engine code scanner ? I have a Iphone 5 and can use that, or just buy a dedicated scanner that i can reset codes with. All i own our OBDII cars so anything with that capability.
Ive replaced the links with the billet 1s and all is good but now i have another issue i want to diagnose.
#17
What is this dealer waiting room you speak of? I once had to go to a shop, but they were pressure testing the cylinder heads I brought them. We ate donuts, and looked at all manner of manly engine bits. The worn wood floors were embedded with the oily dirt you only find in junkyards and machine shops. The fluorescent lights were cheap and loud. No one there ever had a manicure or paid more than 15 bucks for a haircut. Customers Ohhhed and Ahhhhed over the magic wrought by steam cleaning and walnut shell blasting. The wall calendars were all obscene. I need another project just to go back and visit.
#18
#19
I own this one:
It's worked well for all our vehicles (Accord, Bronco & S8), and it's my go to before firing up the laptop and VCDS (an evap leak is an evap leak whether the generic scanner reads it or the Audi software reads it). It stores codes with an actual text description which is nice, and is also battery powered so I can bring it inside without having to write any of the codes down. There are literally hundreds of scanner options out there; just make sure it's got all the bells and whistles you're after. There are basic ones for around $15 that will give DTC codes and clear your CEL, like this one:
#20
