Sponsored by:
Sponsored by:
A8 Overheats, A/C failing intermitently
Old 10-15-2012, 08:45 PM
2000A8's Avatar
Default A8 Overheats, A/C failing intermitently
I have a 2000 Audi A8 w/ ~140k miles. It is now overheating on occasion, for example when stuck in traffic. When moving >25 mph it never overheats.
recently replaced serpentine belt, timing belt, water pump, thermostat, temp sensor.
A/C -- when idling at full stop (e.g. in a parking lot), the air stops blowing as cold, and within a minute, the air is completely warm...absolutely no A/C. Freon has been replaced, with dye, and no leaks detected.
As soon as I get moving again, the A/C turns cold.
I'm thinking these two issues are combined -- possibly the secondary fan is not working and/or the fan clutch is not working?
Thoughts?
Old 10-16-2012, 06:01 AM
tozoM8's Avatar
Your belt driven clutch fan has failed. If you can stop it with a pencil when the car is hot and running, then need a a new clutch.
Old 10-16-2012, 06:11 AM
Kneale Brownson's Avatar
Will that thing seize up and take out the serp belt?
Old 10-29-2012, 11:34 AM
2000A8's Avatar
thanks, fan clutch on order.
audikyle98
02-04-2007 12:11 PM
AdvanSport
09-26-2006 08:57 AM
blodi
05-04-2004 06:25 PM
bogelo
12v V6 Discussion
05-17-2003 09:09 AM
KeithS4
Misc. Models Discussion
03-26-2000 09:09 AM
Quick Reply: A8 Overheats, A/C failing intermitently
