Sponsored by:
Sponsored by:
ABS warning light
Old 05-25-2004, 05:21 AM
NIJ
New Member
NIJ's Avatar
Default ABS warning light
The ABS light comes on somestimes when I brake, I tested the ABS brakes while the light was illuminated in the dash and noticed that the ABS did not kick in, my car just skided. Any ides what could be the cause of this?
Its an A8 4.2 quattro 1998, done around 100k miles now.
Thanks
Old 05-25-2004, 05:34 AM
KaMaKaZieP -ALUMIN8-'s Avatar
Default Clean your ABS sensors on all 4 wheels.
This could solve your problem. My A6 did that. I would start that car and all is good. However once i used the brake for the 1st time the ABS kicked in for a second then the ABS light went on and it disabled itself.
I pulled out all 4 sensors from the wheel, used some brakleen spray and a papertowel. It worked like a charm.
Old 05-25-2004, 05:51 AM
PaulW's Avatar
Concur, common problem
Old 05-25-2004, 06:15 AM
Elder Member
ryoung's Avatar
Default Here's a pic from an escapA8 post
<A HREF="https://forums.audiworld.com/a8/msgs/58282.phtml">Original Post</a>
<img src="http://pictureposter.audiworld.com/31455/escapa8_cv_boot_and_speed_sensor.jpg">
Old 07-05-2004, 11:53 AM
New Member
nitrohepcat's Avatar
Default Re: Clean your ABS sensors on all 4 wheels.
The brake warning light flashes and the ABS light is always on. I pulled the 4 wheel speed sensors and cleaned them with brake clean (they were very dirty).
However, the warning lamp ststus is unchanged.
Old 08-02-2005, 01:53 AM
New Member
kl281071's Avatar
hi,
where are the abs sensors located?. can you help please
pikesaudi
01-11-2011 12:06 PM
Christophe du Bornie
02-28-2009 04:03 PM
S40RCE:Smurf
11
07-07-2007 03:36 PM
hottran
08-26-2004 10:39 AM
Knndad
05-04-2004 10:27 AM
Quick Reply: ABS warning light
