Anyone elses brakes go to the floor after not being used or being on a four point lift?
I left my car for about 3 days and the brakes went to floor until i drove around for awhile, the same thing happened when it was on a lift. Why does this happen?
And is anyone familiar with this leak?
<img src="http://i180.photobucket.com/albums/x125/chenishead/Photo0021-1.jpg" border="0" alt="Photobucket">
<img src="http://i180.photobucket.com/albums/x125/chenishead/Photo0022.jpg" border="0" alt="Photobucket">
><img src="http://i180.photobucket.com/albums/x125/chenishead/DSC01470.jpg" border="0" alt="Photobucket">
inappropriate behavior!
Brake systems are supposed to be "closed".
Nothing in, nothing out, no change in response after sitting or activity.
Do you EVER need to "top up" the fluid resevior?
That would be a sign of trouble. Fluid level should follow pad wear.
Fast cars need good brakes. Get yours fixed!
It might be the master cylinder.
Cal
Cal
Leak is coolant- appears to be a hairline crack in the radiator? Try to trace the leak.....
to the actual source (up higher?). The whitish/pink residue is clearly Pentosin coolant.
^^^^^^^^ what he said
here are a few sign that the brake master cylinder is bad
1. When you press the brake pedal and it slowly go all the way to the floor
2. If you pump on the pedal and it stay a little and then go to the floor.
have the engine running when checking
TRM
08-08-2002 09:19 AM
