In an attempt to get rid of those morning squeaks as the chassis settles in...
I sponged on silicone spray lubricant on all the door seals and think I found the main culprit. The seal on the driver's door that goes to the b-pillar duct/vent squeaks like hell. The passenger side is tight and quiet. How do I get the offending piece out so I can devise a way to tighten it up? I pulled/pried gently but to no avail.
Thanks in advance,
Mark
Thanks in advance,
Mark
ok, I think you mean the piece between the 2 doors that has the phone spkr?
If so, pry up the door sill on each side and you'll see a screw which needs to be removed.
You should be able to remove the screws w/o taking the sill pieces completelty out. After that it's just clips. Pull up and out.
Bob
Bob
rsolberg
07-01-2002 09:00 AM
