Sponsored by:
Sponsored by:
Belly Pan
Old 08-16-2005, 05:42 AM
rellascout's Avatar
Default Belly Pan
I lost my Belly pan over the weekend on my 1998 A8. It was damaged enought that I have concerns putting it back on the car. Is there anywhere you can get one besides the stealer. They want about $275 for the part. Thanks in advance for your help.
Old 08-16-2005, 05:55 AM
Acceler8's Avatar
how did you lose it?
Old 08-16-2005, 06:15 AM
rellascout's Avatar
Default Re: how did you lose it?
Not sure it came off when driving. I believe that the fastners on one side near the passanger wheel well came lose and the whelll pulled it off. It is now damaged on the passanger side and I am concerned that the remaining fastners will not hold it on.
Old 08-16-2005, 06:56 AM
8 misbehavin's Avatar
Default Tie wraps will probably hold it.
Just cut them off and replace them when you need to get under there for servicing.
Old 08-16-2005, 09:52 AM
-OvO-'s Avatar
Default Replacement fasteners are not expensive
even from the stealer. I bought a bunch of them so now I have a couple of spares.
I see that blauparts.com sells a kit of hardware. I think ecstuning does too.
Or are you saying that the fastener holes in the old pan are destroyed and unusable? In which case, I second the advice for zip ties.
I doubt that you'll find a used pan in a boneyard - according to the dealership, they actually stock the belly pan because it gets lost so frequently.
Old 08-16-2005, 10:03 AM
Junior Member
tonypai's Avatar
Default $15-$40 for fasteners at ecstuning.com
<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=4.2&amp;mode l=D2%20A8&amp;submodel=Quattro&amp;category=Exteri or">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=4.2&amp;mode l=D2%20
Old 08-16-2005, 10:29 AM
rellascout's Avatar
Default Re: Replacement fasteners are not expensive
The old pan is broken on the passengers side. The part that clips into the wheel well is gone. I should be able to put 8 of the 10 fastners. Is it worth getting the fastener kit or will there be a lot of wind noise?
Rellascout
Old 08-16-2005, 10:34 AM
Junior Member
tonypai's Avatar
Good question, I've never had a belly pan.
Old 08-16-2005, 10:36 AM
rellascout's Avatar
Default Re: Good question, I've never had a belly pan.
You don't havea belly pan on your car?
Old 08-16-2005, 10:37 AM
Junior Member
tonypai's Avatar
Default Nope. Never noticed it until Paul pointed it out to me.
Makes for easy maintence but I suppose it's nice to have in the winter to keep out the snow and salt.
Quick Reply: Belly Pan
