A/C hookup info
#12
I'm pretty sure my Bentley instructs me to unscrew the switch and install an adapter (an Audi part, of course) on the car to work on it. Its an early 1997, engine code ABZ.
#13
No, the R-12 conversion fitting will not screw onto the car fitting where the low pressure switch is located near the wiper motor on my early 1997 A8Q. That car fitting seems to be an Acme thread, same as what's on my 30 lb R-134a can. My yellow hose will screw on. I was messing with it last night, and seem to have enough hoses and fittings lying around that I was able to cobble together a setup that may work. I have to check for Schraeder valve depressors in it to be sure. The hose colors are all messed up, though. There is a thread or 2 around that says one needs a "tank" adapter for that fitting, which seems to make sense now.
#14
I did get a "tank adapter" fitting on ebay, but it was so long that it bottomed out on the aluminum refrigerant tubing before it could depress the Schraeder valve in the factory port (after unscrewing the low pressure switch normally installed there). So I couldn't get any refrigerant in. The Schraeder valve in the tank adapter gets depressed by the refrigerant charging hose, and then it depresses the factory Schraeder valve.
I was able to grind the tank adapter shorter so that the factory Schraeder valve was able to be depresssed by the tank adapter Schraeder.
Jose Cuervo
12-19-1999 09:22 PM
