Can someone tell me the pin assignments for a pre-facelift S8 instrument cluster please?
Hello fellow '8 owners I've been hanging around here for a while but have only just signed up. I've got a '98 S8 in volcano black pearl which I've had around a month now. Anyway I'm hoping someone can help me out with the pinouts for the instrument cluster on my car as despite a thorough search I've only been able to find the info for facelift cars.
Pre Facelift Instrument Cluster Pin Assignment
Multi-pin connector -A- (26-pin - yellow) assignments
1 - Fuel level sensor signal 2 - Fuel level sensor Ground (GND) 3 - Door contact, driver's door 4 - Ignition key, terminal 86s 5 - Brake fluid level and hydraulic fluid level 6 - Seat belt switch 7 - Washer fluid level 8 - Parking light, right 9 - On board computer reset, left 10 - Board computer reset, right 11 - Board computer reset 12 - Temperature sensor Ground (GND) 13 - Fuel volume sensor (reserve) 14 - Outside air temperature sensor/ AC system 15 - Open 16 - Audio signal "On" 17 - Engine coolant temperature sensor signal 18 - Engine coolant level warning 19 - Brake light 20 - Backup light/low beam headlight 21 - Parking light, left 22 - Coolant fan third speed 23 - Engine oil temperature Ground (GND) 24 - Engine oil temperature 25 - Outside temperature sensor Ground (GND) 26 - A/C compressor "Off" Multi-pin connector -B- (26-pin - red) assignments 1 - Trunk lid 2 - Door contact for driver's door 3 - Door contact, left rear 4 - Door contact, right rear 5 - Fuel level (for OBD II) 6 - Open 7 - Oil pressure 1.2 bar 8 - Open 9 - Transmission range indicator 10 - Open 11 - Auxiliary heater (remote control input) 12 - Hydraulic pressure 13 - Time signal as of ABS system 5.3 (open with ABS system 5.0) 14 - Open 15 - Open 16 - Open 17 - Summer/Winter 18 - RPM signal 19 - Fuel consumption signal 20 - Auxiliary heater 21 - Open 22 - Speedometer vehicle speed signal (output 2) 23 - Speedometer vehicle speed signal (output 1) 24 - Speedometer vehicle speed signal sensor signal (input) 25 - Brake pad wear indicator signal 26 - K-wire Multi-pin connector -C- (26-pin - green) assignments 1 - Open 2 - Open 3 - Open 4 - Open 5 - Open 6 - Airbag 7 - ABS 8 - Door lock (output) 9 - Turn signal, left 10 - Open 11 - Open 12 - Open 13 - Open 14 - Open 15 - ASR 16 - OBD II 17 - Trailer turn signal lights 18 - Open 19 - High beam 20 - Parking brake warning light 21 - Generator (GEN) warning light 22 - Turn signal, right 23 - Open 24 - Open 25 - Airbag (active) 26 - ABS (Sila) Multi-pin connector -D- (6-pin - white) assignments for voltage supply 1 - Terminal 30 2 - Terminal 31 3 - Illumination (3 W) 4 - Illumination for console (40 W) 5 - Terminal 58 6 - Terminal 15 Multi-pin connector -E- (4-pin) assignments for transmitter clock 1 - Transmitter clock signal 2 - Transmitter clock 5V 3 - Open 4 - Radio/Navigation clock ground |
Re: Sure, why do you need it?
Thanks, that was very quick. I'm exploring the possibility of using a 2nd VAG instrument cluster (I have a few lying around) with canbus to convert the relavent signals to send to the facelift climate panel. I needed the pin assignments so I could pick up the required signals. Odd's are it won't work but as I have the clcoks it'll only cost me time.
