Central locking pump problem.
Old Mar 26, 2007 | 02:01 PM
slobo's Avatar
New Member
Default Central locking pump problem.
First off i just want to say hi to everyone I am a new member here, my name is Slobo. I've been driving and working on/modifing a 93 300zx turbo for over 5 years. I recently purchased a 2001 S8 with 38K on the clock. I fixed a few things here and there, vacuum lines, air filter, power steering flush, brake flush, and such, but i'm still getting a "central locking pump faulty(likely leak)" code on vag software. I was quoted by the dealer $540 for part, does anyone know if a pump from 99 A6 will fit? It's exactly the same and part numbers match 8L0 862 257 N.
Thanks and looking forward to beeing a member here.
Old Mar 26, 2007 | 02:49 PM
mpollan's Avatar
Default Same part number = same part. It will fit...
but can this code also mean that you have a leak in one of the lines and the pump is actually OK?
Old Mar 26, 2007 | 03:09 PM
slobo's Avatar
New Member
Default Re: Same part number = same part. It will fit...
I pressurized the lines and it holds vacuum fine, i really doubt there is a leak. Dealer also checked it out and said it was a pump.
I'll get the pump on ebay, I just hope I'll be able to program keyless.
Thank you
Old Mar 27, 2007 | 09:57 PM
svxit's Avatar
Can you post the part no. for the vacuum pump? Mine has been out for a while now. Did not know it was also used in the A6, but now I'm guessing it is also the same part for all D2 A8s.
Old Mar 28, 2007 | 09:38 AM
slobo's Avatar
New Member
part number is 8LO 862 257 N. I should have it by the end of the week, hopefully it will work. Will the new pump have to be adapated or coded a certain way?
Hendie
11
Aug 14, 2021 12:28 PM
Jorge Vargas
Jun 17, 2015 08:52 AM
Slvr86CGT
Apr 11, 2007 04:21 PM
Crisqo09 T.O.
VAG-COM Discussion
Feb 2, 2005 08:29 PM
Wir fahr'n auf der Autobahn
Jan 3, 2005 04:24 PM
