Could anybody direct me - Thanks in advance!
I have few problems (minor I'd say)but it bothers
me. My airbag warning light is always on. Break pads worn out light comes on when I steer to the right. However my break pads are OK. And, I cannot find washer pump - it's not working. It is well hidden. All this on A8 '97 black/black Thanks for any input. |
Re: Could anybody direct me - Thanks in advance!
Washer pump is in the bottom front of washer fluid resevoir.SRS light should probably be taken to the dealer.Maybe a bad/worn sensor for the brake light.Sometimes when shops do brake jobs they reuse the brake sensors.
my brake light is the same
I bought pads but i think it is a sensor. I've seen a post b4 that mentioned a bad sensor wire was a culprit for the light. I'm going to change the pads anyway, hopefully the problem is with the part of the sensor wire you replace with the pads.
