Crank Position Sensor (Early 97 V I N)
Hello... Chasing a no start on a 97 4.2 Quattro. CPS wire on current one is fried. I am having a hard time cross referencing a CPS part number for an early 97 vin car. The connector is rectangular and not D shaped like all the ones I have come up with. Does anyone have a part number for the early vin style connector. The pn on the old sensor is 026121014476343. Thanks
Update: Apparently, I need to wire in this harness adapter p/n 4D0971379, available at various VAG online dealers. At 110 bux and up (not including sensor), I am still researching alternatives in terms of connector parts. I have also emailed Bosch about a possible substitute sensor. Anyone other ideas would be welcomed. Thank you.
ABZ
Thanks J, that looks like it could work... I will try the A4 1.8 sensor above, as I already ordered it and it has a cross referenced number which aligns with a part number that fits the later style connector. I will report back.
I received the above part and installed. The sensor is slightly different in that it has a lip with an oring. It does not quite go in all the way. I did install it. It is not throwing a G28 code, but the car is still not starting. There are no codes being thrown. I found a pigtail and sensor combo at rock auto for around 70 bux. As soon as I figure out the best way and where to splice it in, I will give that sensor/harness a try (su4340). Do I wire the pigtail at the computer? Where would be the best place to splice this sensor pigtail? I will start a separate no start thread going forward. Thanks for the help.
calbear92
10-23-2006 01:56 PM
dgkula
07-20-2006 12:21 PM
cbpldc
10-26-2003 10:36 AM
