crankposition/rpm sensor/ misssfire
#11
Cool...hope you find it
But it's odd that it shows up after the timing belt is changed, that's why I find it hard to believe that it's your ECU. Good luck!!
#12
Re: Cool...hope you find it
yep me too I first thought I messd it up, then I thought I messed up installing the heads you know gasket wise and felt maybe antifreeze was getting in there seeing how its all on the bank.
#13
Re: ?
<center><img src="http://pictureposter.audiworld.com/154401/100_0244.jpg"></center><p>ok finally found the problem or Al at CPT did.
I had the cam to cam timing on one head off. It looked like it was on but after it was pointed out to me. It is a tooth off. Both dots are a little high and so each accounts for a 1/2 tooth. I thought that if they were off it would be more obivous.
Depending on how you look at it it can fool you.here is a pic.
Supradjza80
12-04-2009 11:18 PM
snowman '92 100
Audi 100 / A6 (C4 Platform)
11-28-2003 11:18 PM
chrisfl
05-24-2003 09:45 AM
