D2 '01-S8 - Dead Fuel Pump turns into NIGHTMARE...... (& Member Intro)
#51
Aside from being a good source of parts, it'll be good to know what the problem was in the first instance.
#52
Well it definitely jumped timing. The nylon rollers in the head are destroyed and there is also a good amount of metal shavings under the valve covers...
The one side of the motor that is out of timing gives compression #'s but very weak. The side that IS in timing has ZERO compression. Also seems to have more shavings on this side.
So im left in a ****ty situation.
I can pay for the labor to tear the head off and see whats going on, IF fixable, would still need to be machined, and who knows the extent of replacing valves, valve guides, retainers... who knows what as of this point. And then even if i did have the luck of nothing hitting the bottom end, i would be taking a gamble of rebuilding the head to have it be perfect and fresh and my block (175k) holding up with it. Once the head is tightened up, leaks or problems are bound to arise in the block.
OR I can buy a motor with 60k on it, 6 month warranty, new timing belts, chains, pulley, tensioners, etc..
I cant take that gamble of hoping everything holds together. Im going to tear down the motor when this is all done and see what I find. If anything is salvageable it will be available.
#55
Please take photos...esp under the valve covers...and esp what's left of the cam chain tensioners.
I'm curious and would it be a great archive record of a "catastrophic" failure I haven't seen documented properly.
Unfortunately, the pad material on the chain tensioners is not made to last (or be dependable) past about 100K miles. I caught mine in time and intend to replace the pads on the other side soon, as preventive maintenance.
Sorry to hear, but a great opportunity to document it.
#56
Being 26, having a full time and part time job, and trying to enjoy weekends and your new house is kinda tough without a car!!
#57
I hear ya man, I am 28 and having been waiting for my audi has been nerve racking. you forgot to mention enjoying the house bunnie you have in your av photo as well! she is hot. I am glad I did not have to swap the motor on mine, I hope all goes well and she gets back on the road soon! If you are anywhere near GA I may be interested in picking up your old motor
#58
Picked up the new AYS motor last night and dropped it off at the shop to have swapped out. Hopefully 7-10 days from now I'll be back to driving my pride and joy.
Shokan's description of the donor vehicle was as follows:
"Here is a very nice S8. The car was run tested and we drove it extensively. The complete radiation was good and we ran it for a while. The car had a very nice black leather interior. The drivetrain was in mint condition. All brakes etc were nice. This car had complete electronics, suspension and engine management parts. Thanks for looking."
It was a rear end collision. Motor seemed nice and clean. Nicely prepped and properly plugged by Shokan. Had full timing service done including Timing Belt, Water Pump with gasket, Thermostat with gasket, big roller bearing, small roller bearing, tensioner roller bearing with arm, pneumatic tensioner, serpentine belt, and serpentine belt roller.
Is there anything else I should do while this is all apart?? Suggestions?
#59
I saw your fuel pump saga. Sorry I didn't see it sooner. I created my own solution to that problem that would've saved you a lot of grief. Posted it on your Audizine forum thread
While your wallet is open, buy a VAG Com cable from Ross-tech. It will pay for itself the first time you use it. Otherwise you will be randomly throwing good money after bad.
Good luck, I hope you get it all sorted.
Brian C.
Brian C.
#60
SHE LIVES!!!!
motor is great, feels strong, starts right up....everything i could ask for.... almost forgot how to drive the spaceship once i got back in it!!!!
Audi A8 S8 2001 (D2) for sale
MrMoneyPenny
11-21-2014 07:49 PM
bilbravo
10
01-29-2009 08:52 PM
90sportin
Audi Original "S" Cars
14
04-16-2006 01:53 PM
SteveAngry
06-27-2004 08:48 PM
mrsquig
08-23-2001 05:18 AM
