Sponsored by:
Sponsored by:
D3 rear calipers and a6/passat transmission in a d2?
Old 01-18-2019, 12:48 PM
a8gd's Avatar
Default D3 rear calipers and a6/passat transmission in a d2?
I have seen people saying on ebay that an a6 5sp manual awd can be used in an a8? Is this correct? Would there be modification to the bell housing?
I have also seen threads on this site regarding the d3 rear calipers, Some say if you drill some holes in them they will bolt up? anyone know if this is true?
Thanks!
Old 01-19-2019, 10:52 AM
audinutt's Avatar
The d3 rear calipers have an electronic parking brake so I don't see them as an option (at least in my opinion)
Old 01-20-2019, 01:59 PM
a8gd's Avatar
I swear I have seen some options with the no-electric albeit rare.
But if I'm wrong about that you, are saying the bolt holes and everything else lines up but you must find a way to control the electric or it is unsafe?
Old 01-20-2019, 04:29 PM
jfrahm's Avatar
I do not think people like the electric parking brake very much. Why bother fitting some hokey-*** retrofit electric brake to a D2 when you can just fit good working D2 calipers? If you are looking to retrofit something better (like if you are towing a boat with a lot of tongue weight) then I would chase a proper opposed-piston brake conversion. Even the D3 S8 has a sliding single piston rear caliper though so this style caliper will probably do ya. Unless it's a pretty big boat.
Old 01-21-2019, 08:58 AM
a8gd's Avatar
Looking for max braking for the track on the cheap. I got some D3 front's
JCubed
Q7 MK 1 Discussion
14
05-16-2012 02:15 PM
JCubed
07-20-2008 08:08 PM
Scot W
Audi allroad
12
02-28-2008 03:08 PM
J@RO
Audi 100 / A6 (C4 Platform)
12-22-2007 07:46 PM
6 audis
11-03-2006 07:08 AM
Quick Reply: D3 rear calipers and a6/passat transmission in a d2?
