Eibach Pro Kit with Bilstein Sport Shocks
So after long thought I have decided to go with what DutchDoofus has suggested and get the Bilstein Sport Shocks, factory part number: rear BE3 2609 front BE52616 and the Eibach Pro Kit for my Audi A8 D2.
I just want to make sure that this setup is perfectly compatible with my A8. Is there any special that I might need to add to this setup (spacers...etc.) that is needed and/or would make things even better?
Does this setup need any special alignment after installation (camber adjustment)?
Any suggestions from the more experienced?
Thank you!
Thank you!
Will any old spring compressor work for the install?
I believe that I am also about due for new shocks and springs. I have not yet decided whether to lower the car or go strictly OEM. I took a look at the procedure. One needs a spring compressor. Of course, Audi has their own recommended tool. Will any old spring compressor work for the install or is there a list-member-favorite? I have not yet attempted this kind of job.
Re: I have the exact set up. Just install and enjoy.
Perfect! In your opinion and experience how much the handling got better with the Bilstein + Eibach than with the stock suspension? Do you feel any rolling effect when cornering?
I set my mind on this setup because I hope it will improve a lot in ride stability while still keeps the ride comfortable enough and for this I think the Eibach lowers the vehicle to the perfect hight (not too low and not too high) + the Bilstein gas shocks are amazing I heard. I almost leaned towards the KW variant 2 but that is a bit overkill for the streets and the price is too high also. The Bilstein + Eibach setup is just as good (in my opinion) yet half the price.
Another question I have is that did you need any extra parts for the installation or whatever came in the boxes were the only parts that you needed?
pocketchange
12-02-2018 12:39 PM
EXGTINOWS4
07-05-2004 04:50 AM
sonickeys
10-09-2001 12:49 PM
