Electronic Control Module
Old Oct 24, 2004 | 04:38 PM
backdoc's Avatar
New Member
Default Electronic Control Module
Hooked up my car to the Vag-Com today, just for the hell of it. Checked to see if there were any engine fault codes, and I got the following:
Electronic Control Module Incorrect Coding, Intermittent. Code 18020. The Bentley says the corrective action is to replace the ECM. I had a new ECM installed two years ago from the stealer. The car runs and drives fine, but this code has made me nervous. I'll keep checking to see if the code comes up again. Has anyone gotten this code before?
Doug G.
97 A8Q 110K
Old Oct 24, 2004 | 09:33 PM
skiracer's Avatar
Default Clear the code and keep an eye on it- these intermittent codes.....
pop up fairly often. If it doesn't reappear in a very short time, I wouldn't worry.
Old Oct 25, 2004 | 05:42 AM
backdoc's Avatar
New Member
Will do- Thanks.
Old Dec 3, 2004 | 10:35 AM
dS8's Avatar
dS8
Default Re: Electronic Control Module
New devotee to forum. 1998 A8 103K. Trans fluid/filter changed @63K and now @ 103K. Aluminum and brass in pan. Trans started to really bang the torque converter. EC U tells converter to lock up very early and not to unlock until almost @ stop. Stepping on brake does not get ECU to release converter. Now runs much better as I am using the tiptronic to shift. Am I looking at ECU @ $1400 or ECU/ converter @ $2400 or tranny/ECU/converter @$7000 or any offers to buy?
kakejonny
Feb 8, 2017 04:28 AM
KramS4
VAG-COM Discussion
Oct 13, 2006 12:15 AM
MiSi3k
VAG-COM Discussion
Oct 1, 2003 06:45 AM
Mikey L
Jul 5, 2003 06:38 AM
donp
Jun 11, 2001 07:36 PM
