F125 Switch ...Dead?
How can you check if the F125 switch is dead?
i had a recent error code with the switch
00293 - Multi-function Switch (F125)
05-10 - Input Open - Intermittent
and now it says DTC Error
If it is throwing the code, most likely it is dead. Here is the step by step replacement procedure:
<a href="http://www.audipages.com/Tech_Articles/auto_transmission/f125switchreplace.html">http://www.audipages.com/Tech_Articles/auto_transmission/f125switchreplace.html</a>
The internal switches in the F125 break after a while ( they are plastic ). Also, if water gets into the plug, the corrosion will ruin the connector quickly.
There is a procedure in the Bently
When you shift gears, go very SLOW and deliberate. Dan had the same problem, so did another person I know. The switch fixed it both times.
You would have to go through a lot of troubleshooting via the Bently to verify it is dead, but it most likely is.
pw
pw
EricVonHa
01-08-2009 01:35 PM
G18
01-29-2005 06:00 AM
The Mystro S4
02-02-2003 06:30 AM
BukkakeRocky
10-22-2000 10:16 PM
