Fault Code 1215
Old Jun 23, 2006 | 06:04 AM
SawyerA8's Avatar
New Member
Default Fault Code 1215
Hello All,
It has been sometime since I posted - over a year. Glad to see some of the same names still around. I finally got my timing belt changed at 122K miles - I know - WOW! I went on a road trip after that and my airbag light came on half way though the trip. I checked the manual and it also mentions belt tension on top of the SRS system. So I pulled the code and it was 1215. I cleared the code and it comes back after awhile (random). Anyone know what the code is?
Thank you
Noel Sawyer
1998 A8 quattro
Old Jun 23, 2006 | 06:25 AM
Adrian410225's Avatar
New Member
Default Re: Fault Code 1215
<center><img src="http://pictureposter.audiworld.com/73519/98701374.jpg"></center><p>See the attached pic.
Old Jun 23, 2006 | 06:33 AM
SawyerA8's Avatar
New Member
Default Re: Fault Code 1215 - thank you
I can handle a bad seat sensor - thankfully it was not the belt tension.
Very interesting - my Son was playing in the back seat on the driver side most of the trip and the car was pretty full - trunk also. I'm wondering if something got under the seat or behind the seat. Infact the light went on when he was there last night even after the trip.
Thank you for the post - I'll start my investigating around the seat sensor.
Thanks again,
Noel Sawyer
Old Jun 23, 2006 | 06:55 AM
PaulW's Avatar
Default Take the rear seat bottom out and check to see if the sensor is glued on
Jeff Berstein had the same problem a long time ago....it could very well be the sensor coming unglued from the bottom of the seat.<ul><li><a href="http://www.audipages.com/upgrades/navplusgps.html">How to take the seat out</a></li></ul>
rellascout
Jun 30, 2017 11:52 AM
chemosabe99
Audi A3 / S3 / RS 3
Nov 12, 2012 05:40 PM
PKmode
Dec 28, 2007 12:52 PM
SharkAttack (4.2go)
Jul 23, 2006 10:07 AM
badmyan
Oct 31, 2004 06:16 PM
