Front alignment errors cannot be corrected - suspension work needed...
Did the machine had an option for the S8 or the 1 BD suspension?
If your guy did not checkmark the sports supension 1BD on the machine before the allignment then he probably tried to allign it as an A8 and not as an S8. S8 is lower than the A8.
I am pretty sure that he made a mistake
Do you have your alignment print out. At all our shops, we provide before and after specs to our customers. If so what were alignment specs?
More than likely you have a loose component in your suspension. Any loose component will cause a toe out condition when driving down the road and wear the inside of your tires.
With both 18" and 20" wheels and now at 80k miles, my tire wear has been very good and totally uniform across the tread for the six years I've been running zero toe. Toe-in improves high speed straight line stability, zero toe improves braking and tire wear, toe-out improves turn-in ... which is why some who track their cars run toe-out.<ul><li><a href="https://forums.audiworld.com/a8/msgs/63508.phtml">S8 Alignment Specs</a></li></ul>
i had a similar problem (knock on wood) but its fixed (knock on wood)
i'm just reaching for a suggestion.
In Germany you are therefore forced by law to change shocks every 75k miles :-)
I agree that in the States the roads are pretty poor sometimes but don't under estimate (over estimate ??) the roads here in Holland or Germany or Switserlands.
The highways in Holland and Switserland or France are pretty okay but the B-roads, holy crap they can be bad...
In Germany there are stretches of autobahn that are downright horrible.
That trick i know already but otherwise it's not possible according to my info. Please enlighten me ;-)
Initial Caster: 3.5, 3.9 spec: 3.5
Final: 3.5, 3.9
Initial Camber: -1.5,-1.8 spec: -1.1
Final: -1.6,-1.8
Initial Toe: -0.20,0.35 spec: 0.3
Final: 0.05,0.05
Rear
Initial Camber: -0.8, -0.8 spec: -0.7
Final: -0.8,-0.8
Initial Toe: 0.0, 0.0 spec: 0.2
Final: 0.0,0.05
It sounds like I have some bad control arms and/or bushings so I'm thinking of just replacing it all. Make sense?
Thanks for all the great help everyone!
