Front alignment errors cannot be corrected - suspension work needed...
Old Oct 19, 2008 | 10:47 AM
  #21
skiracer1313's Avatar
Tozo- can you explain how the total camber and caster is adjustable on the S8?
Old Oct 19, 2008 | 10:48 AM
  #22
Ahh, never mind.
Old Oct 19, 2008 | 11:14 AM
  #23
tozoM8's Avatar
Tech Guru
Default Loosen the 4 sub-frame bolt. Move the sub-frame sideways to adjust total camber.
move the sub-frame forward/reverse for caster. It will equalize at 3.7
Old Oct 19, 2008 | 01:06 PM
  #24
DutchDoofus's Avatar
Member
Yep that does the trick indeed.
Old Oct 19, 2008 | 01:07 PM
  #25
TSHong's Avatar
Default Looks like neg camber is on the high side but not to the degree of wearing tires quickly.
on the other hand, the higher neg camber should make you car handle better. Your initial toe readings indicated that the wear was not toe related. It looks like your toe just caused a slightly crooked wheel to the right.
My educated guess would be loose control arms. They are not as easily diagnosed as a loose tire rod. Thats just my opinion.
Old Oct 19, 2008 | 01:53 PM
  #26
OOOOya's Avatar
Tire Source
Old Oct 19, 2008 | 03:15 PM
  #27
Yep, that's where I go too.
Old Oct 19, 2008 | 04:49 PM
  #28
OOOOya's Avatar
Default I figured...
...they've got a great reputation, but not really with me.
Old Oct 20, 2008 | 07:30 AM
  #29
Default The report heading states "Audi,S8,99-03,Quattro Sport Suspension"
so I think his machine had the right setup. It's going to the local dealer tomorrow, as I trust the S8 tech and maybe their alignment system will deliver different results. I also hit a pothole a month ago, so maybe I did minor component damage.
am_ver
36
Dec 3, 2011 08:31 AM
markrQ7
Mar 13, 2009 06:10 AM
AKS4
9
Jun 30, 2004 05:04 PM
spizzi
Jan 20, 2004 07:00 AM
TFG
Mar 2, 2003 06:49 AM
