Having some troubles. Intermittent Trouble starting...Codes listed below! Help is appreciated! TIA!
Saturday,01,November,2008,18:57:14:18301
VCDS Version: Release 805.1
Data version: 20080823
Chassis Type: 4D - Audi A8 D2
Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77
02
VIN: WAUFL54DXYN012860
Address 01: Engine Labels: None
Part No: 4D0 907 560 AL
Component: 4.2L V8/5V G 0001
Coding: 06753
Shop #: WSC 01115
WAUFL54DXYN012860 AUZ7Z0Y1366186
8 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
P1296 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
16816 - Main Catalyst; Bank 2: Efficiency Below Threshold
P0432 - 35-00 - -
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: None
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D26
Coding: 08397
Shop #: WSC 08312
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 08: Auto HVAC Labels: 4D0-820-043-Q.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D12
Coding: 00180
Shop #: WSC 00000
1 Fault Found:
01592 - Air Quality Sensor (G238)
57-10 - Electric Circuit Failure - Intermittent
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 5001
Coding: 00427
Shop #: WSC 01126
No fault code found.
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 D
Component: Lenkradelektronik D01
Coding: 00103
Shop #: WSC 65535
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
Address 17: Instruments Labels:
Part No: 4D0 919 035 AL
Component: D2-KOMBIINSTR. VDO D29
Coding: 02283
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16239
Shop #: WSC 00000
Address 37: Navigation Labels: Redir Fail!
Part No: 4B0 919 887 B
Component: Navigation BNO 0001
Address 45: Inter. Monitor Labels: None
Part No: 4D0 951 177 B
Component: Innenraumueberw. D05
Coding: 00001
Shop #: WSC 00000
Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D03
Coding: 00001
Shop #: WSC 131071
Address 56: Radio Labels: None
Part No: 4D0 035 195 A
Component: Radio D00
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 CP
Component: AG5 01L 4.2l5V USA 1414
Coding: 00002
Shop #: WSC 00000
1 Fault Found:
P1857 - 35-10 - - - Intermittent
End ---------------------------------------------------------------------
02
Coding: 06753
Shop #: WSC 01115
8 Faults Found:
P1423 - 35-00 - -
P1411 - 35-00 - -
P1296 - 35-00 - -
P0432 - 35-00 - -
P0442 - 35-00 - -
Coding: 08397
Shop #: WSC 08312
1 Fault Found:
P1857 - 35-00 - -
Coding: 00180
Shop #: WSC 00000
1 Fault Found:
Coding: 00427
Shop #: WSC 01126
Coding: 00103
Shop #: WSC 65535
1 Fault Found:
Coding: 02283
Shop #: WSC 00000
No Faults Found
Coding: 16239
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 00000
Coding: 00001
Shop #: WSC 131071
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
00-00 - -
Coding: 00002
Shop #: WSC 00000
1 Fault Found:
Here you go---->
This is in the FAQ Digest (for 2 of the codes anyway). PaulW to the rescue!
Clear the codes after replacing the vacuum lines and see if they come back.<ul><li><a href="https://forums.audiworld.com/a8/msgs/19663.phtml">El Lunch Meat Post</a></li></ul>
Python021
03-09-2012 05:37 AM
