headlight washer popped out on way to work
#11
I thought I saw a diagram of the unit so I can see what is going on - probably an o-ring or something, it looks like the bottom part just snaps in - but I don't know. It rotates a little bit (prevented by the hose). If it is just a seal and if that part comes off easily, I think I could do that without removing anything other than the hose.
Eric
#12
Not leaking from the hose - it's leaking from the seal where the bottom part of the washer fits into the upper part.
Eric
Eric
A trouble shoot to do would to see if you can remove the upper portion and just run the lower for a time being (cap off the top with some tap or something or a make shift cover and a zip tie so fluid wont splash out. If you still have a leak its obviously the lower section or something else. If its eliminated there's a crack in the upper section or it's not sealing.
Good luck!
Jason
DeepCover
07-30-2008 07:53 AM
Tornado //S6
Audi Original "S" Cars
10-28-2005 09:51 AM
BukkakeRocky
02-28-2002 11:35 AM
