HELP! Transmission/TCM problems?!
https://cimg6.ibsrv.net/gimg/www.aud...5778a3816.jpeg Gear indicators Hi everyone, having a bit of a problem with my 2001 A8L D2 transmission. Drove it in this morning and everything functioned fine. However A little while (5 mins) after getting in this afternoon the car has acceleration problems, as if the transmission is slipping. The engine functions ok but the shifting is incorrect and when it does shift it shutters a bit. Nursed it home doing about 45-50 (I live about 7miles from town). It should be noted that upon entering the highway and trying to gain a bit of speed all of the gear indicator lights lit up, leading me to believe this is an electrical issue with the TCM or some such component. I restarted the car and the lights didn’t all come on again until I took on a small hill before my house. About a minute after that my check engine light came on. I checked the code with my onboard reader and it’s a PO170. Which I know can mean a lot of things but I’m most interested in the Mass Airflow Sensor as ive heard that can cause transmission malfunction. I don’t want to take it in to a shop because there are not many around here and the closest Audi dealer is 4 hours away. On a final note, all the gears function properly (Reverse, 1-5, Neautral, Park and Tiptronic). Help much appreciated! Mostly wondering if the PO170 has anything to do with it or how to tell if it’s mechanical instead of electrical. Thank you!!! |
All the positions lit up is usually not a good sign; I believe it means the trans has gone into limp mode, which is only one gear, 5th, according to the info I have.
I couldn't find P0170 in my Bentley manual. What engine code do you have? |
Thank for replying so soon! Quick thought wouldent it stay in limp mode once it entered it? Eh I believe the code is in fact PO170 I can double check when I head out to the shop this morning though. I’m no sure(?) The reader (Scangauge 2) only lets me see fault codes. Gonna dig around a bit today and see if I can find water damage anywhere, or loose wires. If the transmission needs replaced I guess so be it. But yesterday it was covered in snow and it got quite warm throughout the day and the snow all melted leading me to believe ya know, water just got somewhere it shouldent. I don’t know haha. I’ll get back on here this evening with what I’ve found |
Originally Posted by flythebigsky
(Post 25138489)
Thank for replying so soon! Quick thought wouldent it stay in limp mode once it entered it? Eh I believe the... I hope I'm wrong and it's just a water issue. Good luck. |
Originally Posted by 2001 S8
(Post 25138676)
Agree with Hillpc, trans failure is starting. There are cases where a transmission will go in limp mode. The owner will pull over and turn the car off and then back on. The transmission will reset itself and operate fine for a short time. Another indicator is the fact you drove the car for 5 minutes and went in to limp mode. As the transmission heat up from driving, the trans will slip causing limp mode.
Here’s the video I was referring to earlier. (
Limp mode.
99.9% sure it is a clutch A basket. It needs a rebuild. |
Originally Posted by tozoM8
(Post 25139593)
Calling Bozeman Audi tomorrow Shops around here useless and I guess if they charge a lot they charge a lot but we’ll see. |
Most dealers will outsource the job, you might look for ZF rebuilders in your area. If it were my car and was worth the cost of repair I would buy a good used transmission, FUN code, and replace the lower valve body on it and install the Transgo replacement valve. Then new seals and install it. I have little faith in rebuilds other than by known-good techs like Tozo. Rebuilders often cut corners and do not address the root cause, and the trans may never be right and may even fail again soon.
I had a really nice FUN code trans (spare part for my 2001) I sold to a list member called Dr. A8 who is located near Salt Lake, his car was wrecked before he installed it. If he still has the trans you might consider getting it and having it installed, maybe $2500 all in. A rebuild is likely $4000 and if your car would be worth $3000 (perhaps an optimistic price) with a good trans you might not wish to perform the work. Good luck, -Joel. |
