Is it me or is the Bentley the most useless when it comes to simple thngs...
like the rear final drive seals.
I have a leak on the passenger side of my rear differential.
It is obvious to me that it's the seal. Please correct me if I'm wrong.
Where do I find info on how to replace this seal in the Bentley, the part name or number for that matter?
Anyone know where I can buy this seal?
Is it this seal?
<ul><li><a href="http://www.pelicanparts.com/euro/catalog/shopcart/W036/POR_W036_SUSaxl_pg1.htm#item3">http://www.pelicanparts.com/euro/catalog/shopcart/W036/POR_W036_SUSaxl_pg1.htm#item3</a</li></ul>
I believe it is part "b 016 409 399 B"
One on each side.<ul><li><a href="http://www.aboveallmotorwerks.com/Products/D-P-H---VAG-Seal-For-differential-output-shaft-(45-X-60-X-8-mm)__D-spc-P-spc-H-spc---spc-VAG_016409399B_S.aspx">Try Here...</a></li></ul>
Everything you need to know is here.....
Thanks to Paul<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/finaldrivesealreplacement.html">http://www.audipages.com/Tech_Articles/auto_transmission/finaldrivesealreplacement.html</a</li></ul>
here's the link for rear diff seals
I would do both at the same time, if the other one's not leaking it will be at any time.
I wrote this procedure a long time ago and would now add:
loosen the rear diff mounting bolts (three at the rear crossmember and 1-2 on the driver side, all hex). Support the diff with a bottle jack. Once the bolts are removed, you'll be able to move the diff slightly from side to side and give you more room to drop the axles down.
Bob<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/finaldrivesealreplacement.html">http://www.audipages.com/Tech_Articles/auto_transmission/finaldrivesealreplacement.html</a</li></ul>
Thank you, thank you, thank you. Audiworld listers are the best.
Owning a D2 would be really difficult and expensive if it weren't for this site and the wisdom of all the listers.
I cannot express this enough.
Thank you all very much.
a lot of times it's the naming convention that makes a search difficult
toothed belt = timing belt
ribbed belt = drive belt
track link = control arms
flange seal = differential seal
etc., etc.
Best thing to do is drill down by category otherwise you'll drive yourself crazy.
Bob
etc., etc.
Bob
iNfiNkC
03-22-2007 05:41 AM
