NO: Headliner
Hello again, I have now fixed my sunroof - but when I attempted to install the headliner the foam just disintegrated and the headliner now has a terrible sag. I was thinking of buying some material from a headliner specialist, light gray/silver velour (I like to keep things as original as possible). I was wondering if someone knew a place which sells a liner similar to Audi's original colour? I checked my VIN and my interior colour code is BT (Lower parts are anthracite black and higher parts are silver/gray).
https://cimg9.ibsrv.net/gimg/www.aud...902833a409.png https://cimg8.ibsrv.net/gimg/www.aud...0706916f9b.png |
I would cut a section and find local headliner supply to bring sample to "match" it.
I have had decent luck scraping the disintegrated foam off the back of the leather door card inserts and using contact cement to reattach the leather. I suppose I could have used a layer of... felt? or something to give it a little more give and perhaps a better overall appearance.
Some chemicals also eat foam, maybe acetone used carefully in your case would leave you with a headliner you could re-use. |
Originally Posted by audinutt
(Post 25801668)
Originally Posted by jfrahm
(Post 25801800)
Some chemicals also eat foam, maybe acetone used carefully in your case would leave you with a headliner you could re-use. https://cimg1.ibsrv.net/gimg/www.aud...be6b729856.jpg |
Try this company: https://www.perfectfit.com/
pillars
Hi. I've got some sunroof frame rattles and am curious how much of the interior needs to be removed to get the headliner out. Do the pillar trims and airbags need to be removed/battery disconnected?
P.S. I cheaped out and used upholstery tacks to hold my sagging headliner, for now. Someday, I would love to do it the right way. Thanks |
Originally Posted by A8Landbarge
(Post 25816560)
P.S. I cheaped out and used upholstery tacks to hold my sagging headliner, for now. Someday, I would love to do it the right way. Thanks As for my part, I did receive the headliner material from Australia... Only to find out that the shade of gray is off. At this point I'm seriously just considering cleaning off and gluing the old headliner fabric over the new one - I really want to keep the OEM look, and there doesn't seem to be anyone who has this headliner in stock anywhere. EDIT: Reference picture below https://cimg7.ibsrv.net/gimg/www.aud...a39aa6c347.jpg |
There is a very simple way to do this. Go to a shop that specializes in headliners and have them do it. I have had headliners drop in both my TT and GTI, and in both cases a local shop had a multitude of matching samples. It's their business after all. I picked the sample and it took a few hours for them to do an absolutely perfect job. And the price was reasonable. If you are truly wanting to replicate the look of the original why would you want to do it yourself? Really, you bought an Audi but you want to save a few bucks by taking on a task which you have probably seldom, if ever, done before? It may look simple. It may be simple. But why not let somebody who does this all day long fix your headliner? I bet they know some tricks you don't.
So after a bit of forth and back I decided to just roll with it. I've cleaned off the backing plate and am now about to cut out the holes in the fabric. It's an awful job but it feels nice to see all the old foam going away.
https://cimg8.ibsrv.net/gimg/www.aud...c5a2584ec8.jpg https://cimg6.ibsrv.net/gimg/www.aud...8dac1e53fd.jpg https://cimg5.ibsrv.net/gimg/www.aud...c5c8e0d5f9.jpg
Originally Posted by durdles
(Post 25818400)
Great project. Looks good!!
