O2 Sensor replacement
Old Apr 18, 2007 | 05:24 AM
hanoking's Avatar
New Member
Default O2 Sensor replacement
I talked with the dealer and they quoted a figure of $1000 to replace both front O2 sensors ($195/sensor + 6 hours of labor). Is it that hard?
Old Apr 18, 2007 | 06:08 AM
A8CT's Avatar
Default Re: O2 Sensor replacement
I've done this twice now on facelift cars. The DR side is easy, the Pass is very difficult to access, it's much easier on a 32v engine.
When I changed the Pass CAT on my wife's car, I found that you might be able to access the sensor through the tie rod cutout and by removing one of the splash shields up top. I haven't actually done it this way though.
I used a LONG 1/2" extension with an impact gun to get them out. It's such a tight fit on the Pass side, it's an 1/8 turn going back in.
They're quoting you OEM sensors which actually make it more difficult. It's easier to use the Bosch universal connections that re-route the existing wiring, at least on the Pass side. They're around $80 a piece.
6 hours seems like a long time though. It's a 3 hour job, tops.
Bob
Kahuna-Big
VAG-COM Discussion
Dec 18, 2009 07:21 PM
Asicks2.7T
Dec 28, 2005 12:09 PM
Eric 2.7
Dec 14, 2004 04:23 PM
awloS4
15
Sep 30, 2003 06:43 PM
shaneS4
Mar 3, 2003 08:35 AM
