oil leak
Cam sensor seals are a common leak point too... SilverD2 is right, you pretty much have to eyeball it, then attack from there. you are sure it's engine oil?
It's easy to find the source of oil leaks with UV dye and a UV flashlight is inexpensive off Ebay or Amazon. You just need to see the fresh dye come out, you can't add it and drive around for a week.
There would be better info from the correct forum but I think your timing set is at the back of the engine and the oil pump is at the front?
