Oil pump......
Oil pump......
Any help would be much appreciated decided to change the pump on the car.... Looked for a good hour on the internet and cant find if this part number 078115105 will fit? the list i did find was ....
Audi Models Audi A4 B5 2.8L V6 30v
Audi A6 allroad 2.7T
Audi A6 C5 2.7T
Audi A6 C5 2.8L V6
Audi S4 B5
Volkswagen Models Volkswagen Passat B5 V6
dont know if the engines are the same in any of those, my first Audi and have alot to learn!
Thanks in advance
Audi A6 C5 2.7T
Audi A6 C5 2.8L V6
Audi S4 B5
Thanks in advance
https://www.audiworld.com/forums/sho....php?t=2844603
Kev13,
ETKA lists a slightly different part # for the Euro model...sorry, I'm not at my PC with ETKA loaded. But this may be just a different Euro # for the same pump.
Logic would say it should fit, since the engines are essentially the same.
What is the code on your engine? "AHA", etc...?
I would also make doubly sure the problem is indeed the pump...oil pump failures are not that common in German engines, but possible I suppose(?).
I have never had an oil pump fail or even decrease it's output in any VW, Audi or Porsche at any mileage.
So the oil pump fit....oil pressure light came on still and grts almost to where i want to be and the engine started making a hurrendous chattering noise (bit like a train!) Loses most of its power more revs the worse the noise so im guessing when it was all sludged it was getting starved of oil and the damage is just showing or something else has gone wrong sounds a bit like the big ends..... so got myself a new engine £350 delivered with 3 months warrenty! Maybe it will cure the oil pressure light problem lmao!
The rattling you hear is not necessarily damage, but a lack of oil pressure getting to the cam adjusters and valves...the cam adjusters alone can make a huge rattle when under-pressurized.
The engine is probably salvageable, but might require a tear down to clean out the sludge.
Good luck
Good luck
Good luck
Ouch! The engine must have spun some rod bearings while the pressure was too low(?)
only one problem now! got new engine in but im stuck with 3 wires left....one thick black one thin black and a big brown one...theyre for the starter motor and the alternator just not sure which ones go where! hoursa and hours trawling through the internet for a picture but NOTHING! any advice would be much appreciated!
Audi A6 C5
12v V6 Discussion
03-27-2017 09:33 AM
Audi A6 Audi Bluetooth A6 C5 models +
03_AR_CO
05-25-2014 11:46 AM
STFA, I have a belly pan off of an Audi PN 4B0 863 823, it says it is made in Switzerland and has an
99.5SilverAudiA4
12-21-2008 01:35 PM
