P0021 p0022 codes
P0021 p0022 codes
Startup rattle is now while running rattle. Threw two codes both bank two. Which side is that? I assume cam tensioner? How bad to run like this? Temp is now 14, would like to wait a little while to repair..
Here's a little first hand knowledge about what is happening under there to cause the noise >>>
http://forums.quattroworld.com/a8/msgs/66027.phtml
And a look inside the bad adjuster, to see why they go bad >>>
http://forums.quattroworld.com/a8/msgs/83599.phtml
So the cam adjuster moves up and down and without the correct amount of pressure it is bouncing and causing the rattle? I'll have to pull the cover tomorrow. Thanks for the info. I found the dissection of the old unit interesting. I wonder if the worn bore could be sleeved?
Has anyone tried these?
http://www.ebay.com/itm/251377988273...84.m1423.l2649
brandonb93
A4 (B7 Platform) Discussion
12
12-04-2018 01:16 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-25-2015 08:57 AM
ECS Tuning-Audi
09-25-2015 08:20 AM
mdkv5
A6 (C7 Platform) Discussion
09-16-2015 01:09 AM
