Quick questions: Alternator life expectancy? Effect of battery condition on Alternator? ...
Also, I searched the forums and noticed many people are changing their "Voltage Regulators" out.
Is this the typical fix for a failing alternator, or is it usually replaced? I understand there's also brushes inside that can wear out, as well as other parts.
My car has 118K miles on it, and I'm due for a new battery. Trying to figure out if it's time to address the alternator?
Thanks!
Thanks!
My 5KCSTQ was sent out to pasture with 330K miles. Voltage reg was replaced once...
as the brushes were worn. This was a $30 part as opposed to $$ for the entire alternator. My alternator charged just fine and made no complaints. I would not concern yourself so much with the alternator itself.
my $0.02,
Mark
my $0.02,
Mark
Re: the voltage regulator has new brushes on it!
If you google "bosch alternator voltage regulator" some parts house will have a picture of the "regulator assembly.
A bit of plastic with two carbon brushes and an "electronic component", the regulator.
If you need one for a face lift model, I have an extra after ordering the wrong part for my 1999. ;-(
On inspection of the unit fitted to my car, with 130k miles, it looks that the brushes are about 75% consumed. I would have replaced the regulator/ brush assembly if I had one in hand when the alternator was out for the oil cooler service.
Regards
Cal
Regards
Cal
Re Different take: Alternator life depends upon environment
Audi likes to hang its alternators where crap off the roads can get to them fairly directly. A belly pan helps, but slop can go through the grille openings.
If you live/drive where winter slop or lots of heavy rains leave you driving so that the alternator gets bathed regularly, the whole thing can develop interior rust. Just a little finger of rust can take out the wire windings. And it raises havoc with bearings and bushings. I get maybe five years out of an alternator on Rust Belt roads awash with ice-melter salt until it's in a condition to require a rebuild.
Funny, on the way home from work the wifey called asked what the "cute" little battery icon meant
so i put it up on the lift dis morning and I could swear its orginal one.I'm sure its had a regulator put in its 267k history.For 1/16 the purchase price of the car it will get rebuilt by the A mish folk.Its ashame its not interchangable with the v6 cars.
Do you still have the facelift regulator? If so let me know, I would like to buy it from you. My alternator on my 2001 A8L is only putting out 13 volts. I have to get a jump to start car if it sits for more than a few days. I am not getting a battery light yet. But I dont think that it is charging the batter fully.
Darren
auditechni@yahoo.com
Darren
JulianHicks
05-23-2018 05:18 AM
Jettamethis
12-19-2011 12:03 PM
Solaris
08-18-2004 08:02 AM
118k, affect, affects, alternator, alternators, battery, car, expectancy, expentancy, life, miles, rebuilt, regulator, replace, voltage, years
