Replacing lower front (straight) control arm .... it's stuck!!!
I was able to remove its attachment point at the frame, shock and to the bar that holds the torsion bar in place. However, the part that sticks through the suspension tower is stuck. I've beaten on it like it owes me money and nothing. Also tried to "lever" it out from the support. No dice. Any ideas?
<img src="http://pictureposter.audiworld.com/55702/dscf0410.jpg">
Try this...
<center><img src="http://pictureposter.audiworld.com/24433/ball_joint_removal.jpg"></center><p>Usually hitting the outer shell of the ball joint will break it loose. Otherwise try a pickle fork or ball joint puller.
HIS4
07-21-2008 11:10 AM
Avanthead
12-11-2007 05:32 AM
StealthMobile
11-05-2007 09:26 PM
