Go Back  AudiWorld Forums > Audi Models > Audi A8 / S8 > A8 / S8 (D2 Platform) Discussion
Reload this Page >
S8 FL 99' Fallen cluster needles (fuel, temp, tacho)
Old 09-13-2018, 07:28 AM
Default S8 FL 99' Fallen cluster needles (fuel, temp, tacho)
Hello. Few weeks ago I bought my first Audi. EU 1999 facelifted S8, not in the greatest condition. I have a problem (one of many haha, driver's door lock is broken and spinning for example) with my cluster needles, they seem to have fallen below their supposed positions (tacho, temp and fuel, speedo is fine). See the attached photo. The gauges seem to work, temp gets to around 50-60 when the car heats up. It looks like they are just moved. Should I just take the cluster apart and reset the needles manually? It seems that the cluster has been taken apart previously, because the tiny plastic round piece next to the tachometer is missing. Thanks.
tomasito is offline
Old 09-14-2018, 11:41 AM
Oxnardo Ring's Avatar
I'd start with re-seating the connectors to the cluster. The "grid" plastic pieces conceal 2 hex head screws that are the only things holding the cluster it. Pop the covers, remove the screws and the cluster will come straight back toward you. Lower-extend the wheel first to give you more room to finesse it out.
Oxnardo Ring is offline
Old 09-26-2018, 10:09 PM
Re-seating the conectors did not work. I ended up reseting needle's starting positions (like in this video:
) and I fixed it, works how its supposed to again. Thank you!
tomasito is offline
Old 09-30-2018, 08:09 AM
Wow. That's a new one... I'll add to my list. thanks.
Basttion
15
03-25-2008 08:19 AM
k7kbm
09-20-2006 12:00 PM
logicbyondreason
02-17-2005 11:21 AM
NeverEnough
10-15-2003 06:46 PM
Quick Reply: S8 FL 99' Fallen cluster needles (fuel, temp, tacho)
