Solar panel relay location
Hi :)
Can someone please help me locate the 385 solar panel relay? My fans does not work, and have read that 99% of the time, the problem is the relay, that controls if the solar panel or battery should be used. Ive checked the footwell relays, which have 2 "rows" of relays in the top in some kind of tray, and beneath there is one row of relays bolted to the frame. But none of them are marked 385...... Are there another location of relays in the D2? Thanks Kim |
Originally Posted by KimHansen
(Post 25097551)
Hi :)
Can someone please help me locate the 385 solar panel relay? My fans does not work, and have read that 99% of the time, the problem is the relay, that controls if the solar panel or battery should be used. Ive checked the footwell relays, which have 2 "rows" of relays in the top in some kind of tray, and beneath there is one row of relays bolted to the frame. But none of them are marked 385...... Are there another location of relays in the D2? Thanks Kim https://www.audiworld.com/forums/a8-...01-s8-2940976/ Here's the relay, if you car's a 2001 - 03 >> https://cimg4.ibsrv.net/gimg/www.aud...f6cc6060a0.jpg |
Okay, ill try the brushes :)
Its a 1997 S8 D2, so it has another relaybox layout. Thanks /Kim |
(Post 25098762)
Haha :)
Im in Denmark, Europe. Picked it up in Cologne, Germany 2 weeks ago. |
Okay then.. bought a new motor, because the.. uhm.. copper wire part of the motor, had been fried.
Now it works :) |
my cabin fan stays on after i turn off the car and now i am pretty sure it is connected to sunroof that also stopped working(opens only half to be precise)
i turn off the car and i can still open and close sunroof,after i do that blower stops,ill try changing this relay |
part number anybody?
does this one fit from a6? 4B0959589 |
didnt see a 203 relay in the footwell,ill try below steering wheel
