Is there any way to buy just the fuel injector plastic pieces?
So removing my injectors, i suspect the first time its ever been done, lead to them breaking while being removed. Only the plastic inserts broke, with the o ring as well. Is there any place I can buy these? Or if not, is it at all possible to just buy a few new injectors instead of all them being new.?
STANDARD MOTOR PRODUCTS SK57 Services Single Injector; Service 1 Injector; Functions: Replacement Fuel Injector O-Ring; Contents: 2 O-Rings, 1 Pintle Cap, 1 Spacer $1.93
Thank you for this information though.
I should say, some injectors have a plastic disk that retains the lower O-ring which usually gets replaced when you service the injectors. This is in place to the pintle cover "hat" that often breaks when injectors are removed, or sometimes these get stuck in the intake.
I do not know what the PFL injectors are like, that kit referenced earlier (which includes plastic pintle caps) as per Rockauto may not be a correct application.
UrSoccer_mobileĀ®
Audi Original "S" Cars
31
10-16-2006 05:30 PM
Jeff Doble
05-01-2003 05:36 AM
Monster1pt8TQ
06-11-2002 07:20 PM
nanotech
05-23-2002 05:45 AM
