Towing problem
of course the more you load IN the truck, the less you can tow behind it because it would count against the trucks gross vehicle weight, so just check you numbers.
also take everything you can out of the audi, 'cause you want as much of the weight to be in the truck, between its axles as you possibly can, and less in trailer or behind the trucks rear axle
in the end, it shouldn't be a problem as long as you check your numbers
