transmission problems
Hey guys...
earlier this morning vag read out the following error code from the A/t
Address 02 -------------------------------------------------------
Controller: 4D0 927 156 E
Component: AG4 GETRIEBE 018 D40
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00293 - Multi-function Switch (F125)
05-10 - Input Open - Intermittent
and now when i check it again...
no Faults found
or DTCs not supported by controller
or a communication error occoured
HUH?
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
no Faults found
HUH?
Mine does that sometimes too
when you try to re-read the fault codes right after having cleared them. Usually another stab and it works fine.
Is there actually something wrong with the trans? IE causing problems with drivability or did you just do a random code pull and got that?
Yeah there was..
while driving to work the rpm started fluctuating wildly and the car was losing adn regaining power while i was accelerating...
So i decided run a check.
I have to tell you ...dtc prblems really worry me.. has anyone had an experiece such as this... ?
Wahhab
Audi Original "S" Cars
10-25-2006 08:38 AM
smoothcruiser
04-17-2004 05:37 AM
