Vag-Com Vorking
Vag-Com Vorking
Finally got my cable and software working and the results are below
VAG-COM Version: Release 311.2-N
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Address 01 -------------------------------------------------------
Controller: 4D0 907 557 J
Component: 4,2L V8/4V MOTR AT D01
Coding: 03263
Shop #: WSC 02314
11 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1 Misfire Detected
P0301 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16686 - Cylinder 2 Misfire Detected
P0302 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
P1327 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
16691 - Cylinder 7 Misfire Detected
P0307 - 35-10 - - - Intermittent
01183 - Warning Light for Catalyst Monitoring (K72)
31-10 - Open or Short to Ground - Intermittent
16689 - Cylinder 5 Misfire Detected
P0305 - 35-10 - - - Intermittent
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4D0 927 156 E
Component: AG4 GETRIEBE 018 D40
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
03-00 - No Signal
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 7680
Coding: 0265109043
Shop #: BB 37680
No fault code found.
Address 08 -------------------------------------------------------
Controller: 4D0 820 043 C
Component: D2-KLIMAVOLLAUTOMAT_D03
Coding: 00180
Shop #: WSC 02314
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4D0 919 033 K
Component: D2-KOMBIINSTRUMENT__D21
Coding: 00183
Shop #: WSC 01588
End -------------------------------------------
How come all my cylinders are misfiring ...Sparks?
Coding: 03263
Shop #: WSC 02314
11 Faults Found:
Readiness: N/A
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
03-00 - No Signal
Coding: 0265109043
Shop #: BB 37680
Coding: 00180
Shop #: WSC 02314
Coding: 00183
Shop #: WSC 01588
Start by changing spark plugs and running a couple of bottles of .....
techron through your fuel system. If it persists, then you need to start looking at electrical causes.
shwndh
VAG-COM Discussion
15
03-17-2008 11:00 AM
pinkertonfloyd
12-10-2006 08:24 PM
Nate (ETKA+Scumbag)
03-08-2006 02:11 PM
