What is a "kraftstoffkuehler"?
<center><img src="http://home.arcor.de/sgrafen/salatoel/alternativen/audi_kraftstoffkuehler_wt_kl.jpg"></center><p>I've seen this on gooogle images under Audi A8 and was wondering what it is, do we need one?
It almost looks like an air pump. I cant imagine an A8
needing a fuel cooler unless the fuel lines are running too close to the manifold in which case they would change the design? Kraft? Hmm, cheese cooler?
kraftstoff = cheese stuff? Can't be! This kuehler has been around since BC time.
BC = before cheese (as *We* know it). The attached post sequence was that infamous instant in time when the world shook and Audi Cheese, Cheez, Cheeze, etc. was born... :-)<ul><li><a href="https://forums.audiworld.com/a8/msgs/46186.phtml">https://forums.audiworld.com/a8/msgs/46186.phtml</a</li></ul>
Looks like a fuel cool can used in drag racing.
To get the last bit of volumetric eficiency and HP out of the motor, you can cool the fuel to reduce the intake charge temperature. Normally you fill the <A HREF="http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2716&prmenbr=361">Cool Can</a> with dry ice before each run. Your pic looks like refrigerant is piped to the can, which would seem to be self defeating if it's from a motor driven A/C system.
<img src="http://www.jegs.com/photos/71065125.gif"><img src="http://www.jegs.com/photos/71097817.gif">
Yes it means "fuel cooler"
German has wonderful composite nouns ...
pick any two or more nouns and simply combine them into a new word. Most likely you will have a valid noun that makes sense within the appropriate context.
Greenie, this is for you:
käse = cheese
kuchen = cake
suppe = soup
fuesse = feet
brot = bread
Guess what Käsekuchen, Käsesuppe, Käsebrot, Käsefüße mean.<ul><li><a href="http://www.kaeseseite.de/">Käseseite ... seite means page in German</a></li></ul>
käse = cheese
kuchen = cake
suppe = soup
fuesse = feet
brot = bread
fuel gets hot
with an mpi system as fuel is taken from the fuel rail, and the rail is kept at high pressure, there is substantial surplus fuel, this surplus fuel (un-metered) needs to be returned to the tank via it's own return line (whcih is why there are 2 fuel lines)- this warms the fuel in the tank.
newer mpi (also fsi) systems with direct injection meter the fuel accurately so that there is no need for a return line, and so the fuel tank doesn't get hot.
