Where is bestPlace toGet transmission fluid & complete change kit 2000 A8 w/EDG tran
Re: 2000 A8 with Tiptronic 5-speed, and transmission code EDG
I'm new to this vehicle and need to know the best place to get:
Transmission fluid
Transmission change kit
I know how to do the job, just need the best place to get the supplies.
Transmission fluid
Welcome to the club! Couple of good online stores below:Good luck.
I use Valvoline Max Life ATF. Myele gasket. Maybe a Meistersatz Transmission Filter. Where to get depends on where you live, I got parts from Amazon and Ebay but I am in the USA.
Consider the TransGo valve replacement to avoid future significant trans problems.
I've done all my transmission fluid changes using Mobil 1 ATF which I buy from Amazon in 6qt cases. It's usually cheapest that way or otherwise you are paying like $10/qt locally. I think I usually use about 8-9qts each time I change the fluid.
As for my filter and gasket kit, I have used the Meyle kit every time. I purchase my filter kits two at a time along with Mahle fuel and/or oil filters to save on shipping.
http://www.autohausaz.com/pn/01L398009B
2000 A8 4.2L AKB EDG with 252,900 miles and still going......
spdemon91
03-31-2019 12:33 AM
crusininda944
Audi 100 / A6 (C4 Platform)
06-20-2008 05:35 AM
A8L_Driver_Dan
26
01-27-2004 08:06 AM
