Go Back  AudiWorld Forums > Audi Models > Audi A8 / S8 > A8 / S8 (D2 Platform) Discussion
Reload this Page >
why is my A/C condenser line blocking my radiator drain plug?
Old 04-29-2019, 01:54 PM
Default why is my A/C condenser line blocking my radiator drain plug?
It's smack dab in front of the drain, less than 1/2" away. There's no way I can see to get a screwdriver in there through the
grill opening in the bumper. I had a hard enough time on a lift, with the bumper off. Did the previous owner put the condenser in the wrong spot?
A/C line blocking radiator drain plug access
hillpc is offline
Old 04-29-2019, 06:00 PM
something's wrong, the condensor should be on the front (closer to the bumper)
audinutt is offline
Old 04-30-2019, 03:39 AM
It doesn't seem like the condenser could be mislocated; it has very definite, fixed rubber mounting points on the front of the radiator. Weird. I'm accessing the drain plug from the front with the bumper off, with a small pair of pliers around the outside of it to rotate it. Once I have it broken free, then I can use a screwdriver to get into half of one slot, at an angle. There's no way I could do that with the bumper on, through the access grille. (Or I don't have the correct tool.) The pix below show how tight it is.
view from driver's side
view from front
hillpc is offline
seko
01-30-2009 10:18 AM
Vee8
23
02-18-2007 03:11 PM
DanAudi90
10-28-2004 07:19 PM
Infamous
01-03-2004 05:15 PM
jasonelise
06-08-2002 10:59 AM
Quick Reply: why is my A/C condenser line blocking my radiator drain plug?
