Windshield washer fluid, not working, fuse location?
Hi. I've been around the block on the forums and online trying to find the cause of my washer fluid not working. I have a '01 S8. I'm hoping someone can help. Here is where I'm at:
- The fuse block does not show a fuse for "washer pump". Is there one? - All the fuses are good - Headlight washers work - Relay 4,9 was replaced at some point. Intermittent wiper works and I hear it clicking when I pull the handle back but I can't tell if that's just the wiper relay "click" - Does this relay control the washer fluid? - There are no volts at the windshield washer pump when activated I haven't tried to track down a faulty wire yet because I'm not sure where to go if that's the next step. Thanks. Paul |
It's likely the pump itself, I had to replace them on both of my d2's within the past year.
Originally Posted by audinutt
(Post 25242554)
