07 A8 Rear Air Suspension Issues after Jacking
#41
OK, Saturday morning, put wheels back on and put the car on the ground, on 3" of wood under each wheel. Car seemed low before I started it, when started, it pumped up to what I would say is a normal height, rear is back up but I don't know why! I made sure all tires had same pressure to make things more accurate. It seems that the rear is back after cycling a couple times between dynamic and comfort. The left rear seems to be about .25" higher than the rest of the car. One thing suspicious is the pressure went up to only 8 bar or so. I am suspecting the compressor is weak and I might go ahead and rering it to make sure it is good. I don't like that low pressure as the compressor would work harder than it has to. I have no idea what i did to fix the rear suspension but it seems to be holding. I am not going to put it in lift and then jack mode and let it sit overnight and take readings and measurements tomorrow. If nothing sags I think I will redo the compressor and put it back together. I'd appreciate your input on the latest info I have posted. Thanks!
Group 34 readings below:
Address 34: Level Control (4E0 910 553 H)
09:25:54 Group 003
High level selected
[N/A]
Lower level selected
Relay OFF Compressor Status
09:25:54 Group 004: Deviation from standard level
-20.0 mm Front Left
-20.0 mm Front Right
-20.0 mm Rear Left
-22.0 mm Rear Right
09:25:54 Group 006
21.0°C Compressor temperature
8.46 bar Pressure sensor signal
OFF Drain valve Status
OFF Pressure accu. valve
09:29:35 Group 003
High level selected
[N/A]
09:29:35 Group 004: Deviation from standard level
23.0 mm Front Left
23.0 mm Front Right
27.0 mm Rear Left
24.0 mm Rear Right
09:29:35 Group 006
52.0°C Compressor temperature
2.28 bar Pressure sensor signal
09:25:54 Group 003
High level selected
[N/A]
-20.0 mm Front Left
-20.0 mm Rear Left
-22.0 mm Rear Right
09:25:54 Group 006
09:29:35 Group 003
High level selected
[N/A]
23.0 mm Front Left
23.0 mm Front Right
27.0 mm Rear Left
24.0 mm Rear Right
09:29:35 Group 006
#43
My 05 A8L W12 is on all original struts, level sensors, and compressor, closing in on 200K
JJJ
#44
I had the car in lift mode and jack mode since Saturday, took new measurements tonight. Here is how they compare
Saturday Tuesday (tonight)
LR 33.125 33.125
LF 33.25 32.75
RR 32.75 32
RF 32.875 32.5
I guess that's OK? If that is the consensus I guess I will put the inner fender liners back on and drive it again.
LR 33.125 33.125
LF 33.25 32.75
RR 32.75 32
RF 32.875 32.5
#45
OK, I got the wheels back on and drove the car, no suspension lights and things seem to be holding up well. I will VCDS scan later to see what the pressures are I'm not sure what was causing my issue at this point. Thanks everyone for the help!
#46
After the jacking up, the system needs sometimes to sense and control everything back to the optimum state... That's how a control system works, a good one at that, trust Audi's systems, they're quite well designed regardless of what people say.
Cheers,
Louis
Cheers,
Louis
#48
Yellow light points to some issue still being present, unfortunately. If the issue was a leak, I'd think you would see more drop with it parked if it was bad enough to trip lights while driving, but not necessarily.
#49
Yellow light on solid, in dynamic and the others are grayed out, but i think that will change when I restart the car. These are the codes that are coming up today. Car is at the right height I believe
Thursday,17,January,2019,15:15:56:24716
VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64
Ross-Tech: Home
Address 34: Level Control Labels: 4E0-910-553.clb
Control Module Part Number: 4E0 910 553 H HW: 4E0 907 553 F
Component and/or Version: LUFTFDR.-CDC H06 4480
Software Coding: 0019911
Work Shop Code: WSC 11111 111 45799
VCID: 2809043BDEF51387F6B-807C
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 15
Reset counter: 132
Mileage: 259967 km
Time Indication: 0
Date: 2019.01.12
Time: 09:52:57
01400 - Suspension Level Control
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 6
Reset counter: 92
Mileage: 259987 km
Time Indication: 0
Date: 2019.01.12
Time: 15:23:01
Cleared the codes, yellow light came back on and I haven't moved the car, this code came back
Ross-Tech: Home
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 132
Mileage: 259967 km
Time Indication: 0
Date: 2019.01.12
Time: 09:52:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 92
Mileage: 259987 km
Time Indication: 0
Date: 2019.01.12
Time: 15:23:01
Ross-Tech: Home
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 132
Mileage: 259967 km
Time Indication: 0
Date: 2019.01.12
Time: 09:52:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 92
Mileage: 259987 km
Time Indication: 0
Date: 2019.01.12
Time: 15:23:01
Ross-Tech: Home
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 15
Reset counter: 132
Mileage: 259967 km
Time Indication: 0
Date: 2019.01.12
Time: 09:52:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 92
Mileage: 259987 km
Time Indication: 0
Date: 2019.01.12
Time: 15:23:01
