07 Control Head security Access Code needed
There is a guy in Europe who has bootlegged a method for like $40.00 US as long as you have the right interface and internet connection on a computer you can hook to the car.
Not sure of his CONtact info but someone here can chime in with it.
Usually charges 50 euros
Let us know the result of your visit to Audi.
Also what is the error code for the Mmi head unit 07
There isn't a malfunction for the 07 Control Head. there is on the central conv. , the battery regul. the rear left door, the tire pressure module, and telematics.
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
you could pick up a cheap control board off ebay, or if you are good with circuits and soldering you could solder in a touch pad or just a jumper to simulate the button and see if the car menu appears.
EDIT: Going to pull the center control out and get to the circuit board to jump pins on the button. I figure if the micro switch failed from the soda spill then I will solder out the telephone M-switch with the car M-switch since I know it works and do not use this feature. Will report back with updates this evening.
