09 A8L Kessy Failure Help/advice
Just bought this 2009 A8, Scanned multiple time with VCDS and Abrites. Cannot access Kessy/immobilizer at all. Sometime it will connect but will not talk. I have the original key with a good battery and new car battery a with full charge. Fuses and wiring are good. Kessy will not recognize key. No dash lights at all, radio works and display will work. If i rapidly cycle the key all of the dash lights will come on, lots of clicking and lights on and off. Powered up terminal 15 and read ECM and TCM mostly communication codes stored. No sign of water damage in modules. I tried replacing mosfets on kessy and that did not work. Steering lock does not lock with terminal 15 off. Ignition lock defective when dash lights up.
My next step is to buy kessy and have it coded to car. Does anyone know of someone who has Vas and Geko account and is willing to help me with this? Thanks, Frank VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 Ross-Tech: Home VIN: WAUMV94E79N002032 License Plate: Mileage: 133600km-83015mi Repair Order: Chassis Type: 4E (4L0) Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 27 28 34 36 37 38 3C 42 46 47 4F 52 53 55 56 5C 61 62 65 67 6C 6F 72 76 77 VIN: WAUMV94E79N002032 Mileage: 133600km-83015miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 27-Ctrl Head, Rear -- Status: Cannot be reached 1100 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 3C-Lane Change -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5C-Lane Maintain. -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 67-Voice Control -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: Malfunction 0010 6F-Centr. Conv. II -- Status: Cannot be reached 1100 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: VCID: D5E2DA012CB9B4EE09-FFFE Note: Excessive Comm Errors ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4E1 910 156 C HW: 09L 927 156 A Component: AG6 09L 4,2lFSI USA 0040 Revision: --H01--- Serial number: 4441621 Coding: 0000002 Shop #: WSC 49027 001 1048576 VCID: A306B4D9626D1A5E37-80F6 5 Faults Found: 049446 - No Communications with Steering Angle Sender (G85) U0126 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:10:04 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 24.0 Temperature: 26.0°C T.B. Angle: 0.0° 049442 - No Communication with ESP (Vehicle Dynamics) Control Module U0122 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:10:04 049448 - No Communications with Parking Brake Control Module U0128 - 000 - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:13:44 006273 - Powertrain Data Bus: Missing Message P1881 - 000 - Acceleration Request - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:37 013093 - Power Supply Terminal 15 P3325 - 000 - Implausible - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:38 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071520 Shop #: WSC 02313 785 00200 VCID: A404B7C567631D664E-80F0 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 732 T HW: 4E0 035 729 A Component: Interfacebox H43 4610 Revision: 00000000 Serial number: 348E$087529574 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: B3264499D28D8ADEC7-80E6 Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0050 Subsystem 2 - Serial number: 00000000066856 Subsystem 3 - Serial number: 0128.05.080000000100010011˙ Subsystem 4 - Serial number: 010011˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000150337 Coding: 0102737 Shop #: WSC 02311 785 00200 VCID: 9C748F255F1325A6F6-80C8 7 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:18 Freeze Frame: Voltage: 11.40 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:18 Freeze Frame: Voltage: 11.50 V 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 205 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:13:59 Freeze Frame: Bin. Bits: 00011111 00819 - High Pressure Sensor (G65) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:41 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 205 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:41 Freeze Frame: Temperature: 24.0°C 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 205 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:41 00565 - Rear A/C Control Head (Climatronic) (E265) 013 - Check DTC Memory Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 205 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:41 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 S HW: 4E0 907 279 S Component: ILM Fahrer H16 0240 Coding: 0143123 Shop #: WSC 02313 785 00200 VCID: B83C73B5CBEB6986F2-80EC Subsystem 1 - Part No: 4E1 910 113 C Component: Wischer WWS D3 H60 0420 Coding: 00000037 Shop #: WSC 02313 Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH04 0003 Coding: 00150573 Shop #: WSC 02313 2 Faults Found: 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:07:33 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 31 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:05 ------------------------------------------------------------------------------- Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H15 0850 Revision: 00000000 Coding: 020000 Shop #: WSC 02399 823 56573 VCID: AB165CF9CABDD21E8F-80FE No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl Part No SW: 4E0 910 593 M HW: 4E0 035 593 F Component: SDAR SIRIUS H07 0160 Revision: 00000000 Serial number: AUZ4Z7H0327363 Coding: 0000100 Shop #: WSC 02313 785 00200 VCID: B12A4E912891B8CEB5-80E4 3 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 07:02:39 Freeze Frame: Voltage: 8.40 V 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 07:02:09 Freeze Frame: Voltage: 8.40 V 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:20:44 ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 15: Airbags Labels: None Part No SW: 4E0 910 655 F HW: 4E0 959 655 L Component: Airbag 9.41 H01 4230 Revision: 91H01423 Serial number: 003CV00039Z7 Coding: 0532707 Shop #: WSC 02313 785 00200 VCID: A91AA6F10041C00E7D-80FC Subsystem 1 - Serial number: 63328RB403D0FCDA1 Subsystem 2 - Serial number: 63428RB403D0FBB0W Subsystem 3 - Serial number: 63528RB403D0FCD5+ Subsystem 4 - Serial number: 63628RB403D0FCDF9 Subsystem 5 - Serial number: 63729RB403CD1917T Subsystem 6 - Serial number: 63829RB403CD1D3D% 5 Faults Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:05:10 00591 - Seat Belt Switch; Driver (E24) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 02:45:06 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 02:45:07 01742 - Igniter for Knee Airbag; Drivers Side (N295) 001 - Upper Limit Exceeded - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:04:06 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:13:55 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 A HW: 4E0 953 549 B Component: J0527 0410 Revision: 00H04000 Serial number: 90055080960048 Coding: 0032351 Shop #: WSC 02311 785 00200 VCID: A600ADCD115FEF7650-80F2 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 H01 0030 2 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:07:34 02797 - Control Module for Directional Stabilization Assistance (J759) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 3 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:48 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 981 D HW: 4E0 920 981 D Component: KOMBIINSTR. VDO H84 0620 Revision: D03 Serial number: AUDID3H5100021 Coding: 0048283 Shop #: WSC 49027 067 57207 VCID: A91AA6F10041C00E7D-80FC No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4L0-910-468.clb Part No SW: 4L0 910 468 A HW: 4E0 907 468 H Component: J533__Gateway H06 0060 Revision: 00H06000 Serial number: 0200J08507802F Coding: F5F7DF7F7F7A0E00 Shop #: WSC 02313 785 00200 VCID: AD1252E134A9DC2E91-80F8 2 Faults Found: 02874 - Control Module 2 for Central Convenience (J773) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:21:32 00460 - Control Module for Display and Input; Rear (J524) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:22:31 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H46 0390 Revision: 00046002 Serial number: AUZ5ZBH8444138 Shop #: WSC 00000 000 00000 VCID: 9A78893D55275B96E4-80CE No fault code found. ------------------------------------------------------------------------------- Address 27: Ctrl Head, Rear Cannot be reached ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: None Part No SW: 4E0 910 158 HW: 4E0 919 158 D Component: KLIMA-STG. FOND 017 0230 Revision: 00000020 Serial number: 00000000091330 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: E18AFED138F1484E65-80B4 6 Faults Found: 01087 - Basic Setting Not Performed 005 - No or Incorrect Basic Setting / Adaptation 01864 - Air Outlet Motor; Rear Right (V219) 003 - Mechanical Failure 01863 - Air Outlet Motor; Rear Left (V218) 003 - Mechanical Failure 01850 - Temperature Sensor for Heated Seat; Rear Right (G95) 010 - Open or Short to Plus 01849 - Temperature Sensor for Heated Seat; Rear Left (G94) 010 - Open or Short to Plus 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 34: Level Control Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4071530 Shop #: WSC 02313 785 00200 VCID: A404B7C567631D664E-80F0 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 M HW: 4E0 919 887 M Component: MNS US H51 1100 Revision: 00000000 Serial number: 395EW087515390 Shop #: WSC 02313 785 00200 VCID: B83C73B5CBEB6986F2-80EC No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000921100012 Coding: 0003477 Shop #: WSC 08219 444 53385 VCID: 9D72822144092CAE01-80C8 4 Faults Found: 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:00 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 2 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:00 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:00 00457 - Control Module for Network (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:22:00 ------------------------------------------------------------------------------- Address 3C: Lane Change Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 801 F Component: Türsteuer.FS BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: A00CBBD5737B01462A-80F4 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 E HW: 4E0 907 289 E Component: Komfortgeraet H10 0030 Revision: 00300010 Serial number: W040806030170 Coding: 0048686 Shop #: WSC 02313 785 00200 VCID: AB165CF90ABDD21E8F-80FE Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 5 Faults Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 4 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:10:05 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:10:21 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 3 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:05:15 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:13:41 01366 - Opened Due to Crash Signal 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:42 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H03 0120 Revision: PROD_01 Serial number: 00000000100603 Coding: 0000026 Shop #: WSC 02313 785 00200 VCID: AC145FE50FB3D52686-80F8 4 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 11 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 05:41:13 Freeze Frame: Voltage: 8.30 V 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 13 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 05:40:23 Freeze Frame: Voltage: 8.30 V 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 6 Fault Frequency: 2 Reset counter: 206 Time Indication: 0 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:05:19 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 D Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000025343 Coding: 0010111 Shop #: WSC 02313 785 00200 VCID: 9E70852D490F37B618-80CA 1 Fault Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 166 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:04:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E1 959 802 F Component: Türsteuer.BF BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: A00CBBD5737B01462A-80F4 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000922 Shop #: WSC 00020 210 01865 VCID: A00CBBD5737B01462A-80F4 5 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 2 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:09:53 Freeze Frame: Voltage: 11.18 V Count: 247 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:40 Freeze Frame: Voltage: 10.97 V Count: 244 01316 - ABS Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:27:47 Freeze Frame: Voltage: 11.28 V Count: 231 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 33 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:22 Freeze Frame: Voltage: 10.66 V Count: 242 02443 - Control Head 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00111100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 206 Time Indication: 0 Freeze Frame: Voltage: 5.07 V Count: 40 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 542 Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 352F%087658398 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: B12A4E912891B8CEB5-80E4 No fault code found. ------------------------------------------------------------------------------- Address 5C: Lane Maintain. Labels: VCID: D5E2DA012CB9B4EE09-FFFE ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000009846 Shop #: WSC 08219 444 54679 VCID: A00CBBD5737B01462A-80F4 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2806030311 Coding: 344530393135313035412056413032383036303330333131 Shop #: WSC 49027 001 1048576 3 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 16 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:09:36 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 40 Reset counter: 255 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:12:34 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 10 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:08:55 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: 9E70852D490F37B618-80CA No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 A HW: 4F0 907 273 A Component: Reifendruck 3 H05 Revision: 00050340 Serial number: 00000900058099 Coding: 0232125 Shop #: WSC 02313 785 00200 VCID: A00CBBD5737B01462A-80F4 2 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent - MIL ON Freeze Frame: Fault Status: 10100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:09:08 Freeze Frame: (no units): 255.0 Voltage: 5.70 V (no units): 33.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. 01299 - Diagnostic Interface for Data Bus (J533) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 3 Fault Frequency: 5 Reset counter: 166 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:02:14 Freeze Frame: (no units): 255.0 Voltage: 0.00 V (no units): 27.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A Component: SDS 3501 US H46 0630 Revision: 00000000 Serial number: 00000805300124 Shop #: WSC 12336 024 394758 VCID: B4244785D7838DE6DE-80E0 3 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 05:40:14 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 5 Fault Frequency: 7 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:12 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 5 Fault Frequency: 7 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:00:12 ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 4E0-910-441.clb Part No SW: 4E0 910 441 HW: 4L0 907 441 A Component: J772__Rearview 0050 Revision: --H12--- Serial number: 525PA8-J84111W Coding: 1120403 Shop #: WSC 02313 785 00200 VCID: DCF4CF251F9365A636-8088 8 Faults Found: 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:41 Freeze Frame: Term 15 Off Reverse OFF Count: 3 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 13 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 21:31:27 Freeze Frame: Term 15 Off Reverse OFF Count: 3 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 7 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 21:36:47 Freeze Frame: Term 15 Off Reverse OFF Count: 3 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 81 Reset counter: 206 Time Indication: 0 Freeze Frame: Term 15 Off Reverse OFF Count: 3 01330 - Central Control Module for Central Convenience (J393) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 75 Reset counter: 206 Time Indication: 0 Freeze Frame: Term 15 Off Reverse OFF Count: 3 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 8 Reset counter: 206 Time Indication: 0 Freeze Frame: Invalid Invalid Invalid 00778 - Steering Angle Sensor (G85) 013 - Check DTC Memory Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 2 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:17:41 Freeze Frame: Term 15 Off Reverse OFF Count: 3 01327 - Control Module for Parking Aid (J446) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:31:19 Freeze Frame: Term 15 Off Reverse OFF Count: 3 ------------------------------------------------------------------------------- Address 6F: Centr. Conv. II Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: Türsteuer.HR BRM005 0180 Coding: 0032364 Shop #: WSC 02313 785 00200 VCID: 9E70852D490F37B618-80CA 4 Faults Found: 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:19:44 02128 - Door Closing Control Module (J657) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 0 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:48:02 00532 - Supply Voltage B+ 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 0 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:48:32 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 206 Mileage: 133600 km Time Indication: 0 Date: 2016.08.13 Time: 00:03:20 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08720814901573 Coding: 0221208 Shop #: WSC 02313 785 00200 VCID: A306B4D9626D1A5E37-80F6 6 Faults Found: 01549 - Supply Voltage for Parking-Aid Sensor 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 9 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:08:56 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 15 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:22:18 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 6 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:23:51 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 8 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:08:58 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 8 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:08:55 01549 - Supply Voltage for Parking-Aid Sensor 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 7 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 00:09:05 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 G HW: 4E0 862 335 Component: Handyvorb2 H20 1120 Revision: 00000000 Serial number: 00000005043478 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: A71EA0C91655F67E6B-80F2 2 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 41 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 05:41:13 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 206 Mileage: 133602 km Time Indication: 0 Date: 2016.08.13 Time: 06:01:45 End----------(Elapsed Time: 03:45, VBatt start/end: 12.3V/12.2V)----------- |
This one is FIXED!!! Thanks from Storka for the reference, Ross-Tech for tech support and Jack from Poland for programming. Kessy was bad and a Virgin kessy was programmed and this A8L came alive. Thank you for all your help.....
Frank |
Originally Posted by fvuoso
(Post 25062900)
Frank Thanks in advance Mime 04 Audi A8L 4.2L V8 |
(Post 25062900)
Frank Thanks in advance Mike 04 Audi A8L 4.2L V8 |
Same question from me
