2006 A8 cigarette lighters, cup holder lights and vent lights not working
Greetings everyone!
I have an 06 A8 and as the title says, the front and rear cigarette lighters as well as the cup holder light, front ash tray light, all of the vent illuminations and also all of the buttons on the silver trim piece that goes across the dash just underneath the MMI screen are all off and not working. It seems to be a common denominator but I am not sure what is wrong. I did check the fuses on both sides of the dash, they are all good.
I searched and have found a couple of other threads on other places online with people with the exact same issue, but no one ever replied what their solution was.
Any ideas?
Also, I am new here and have a general question - what are the requirements to be able to post to the classifieds section?
Thanks in advance for the help!
Any ideas?
Banned
Wonderful! Thank you very much for posting this, I've been searching for information for so long now... I will take apart the armrests this weekend and will report back so others can solve this issue if they ever encounter it!
How is the Bentley going JJQ?
Your A8L must be doing well, haven't seen you here for a while, I started to see some B Coupe s driving around and some of my friends even mention about them... Is it a fad these days with B? How do they really drive like?
Cheers,
Louis
Cheers,
Louis
PROBLEM SOLVED!
Thank you for the help guys, today I got to the bottom of the issue. The problem was caused by a pinched and shorted wire inside the swivel mechanism on the passenger arm rest. There is a black/red wire that goes into the arm rest to illuminate the red LED. The cable runs up the central shaft that holds the arm rests, and then winds around a grommet and goes into the arm rest, and over the years from moving it up/down the red and black wires become exposed and short out, causing half of the dashboard lights to go out.
I simply spliced the wires together again, isolated them with electrical tape, and all of the dash lights work
Special thanks to JohnnyJ A6Q for pointing out that thread to me. Let me know if you have a Dogecoin address and I'll tip you
Thanks for the post - I just realized my vent dials
and the other lights are not working also. I need to look at the wires too. My cigarette lighters work though.
Cheers,
Louis
Cheers,
Louis
Banned
I am back..... :(
Blackraven,
I am very glad my thread helped you fix this, and just to clarify for Louis, I believe your cigarette lighters still functioned as far as heating element and just the lighting around them was non functional along with switches and vents as was the case when I found the cut wire in my passenger side armrest.
Hello Louis,
I have yet to drive my "B GT" as she is still in the working on it stage.....
Plus I just returned from a month in Italy, So it's time to get back to her.
Buongiorno, JJJ
Hello Louis,
Buongiorno, JJJ
