2006 Audi A8 Ride Height
Hello, I just bought a 2006 Audi A8 with the 4.2L engine. The previous owner "lowered" the car by putting lowering links or/and VAG COM software adjustments. He does not have the factory links. Can I get the height back to factory heights using the lowered links and VAGCOM?
Cheers and good luck,
Louis
Factory heights from wheel center to the lower edge of the fender:
Audi A8 D3 standard suspension: 416 mm (front) 398 mm (rear)
You can re-adapt the default ride height if you have vcds.
I liked the look, however my wife did not. The seller is 25 years old and I guess they like it that way. hank you.
Just be careful, make sure the USB port is not loose, serial signals are good.
Yeah, I remembered got the cheapest cars, lowered them, changed mufflers to sound better or not... wasted time and money... but then, it’s all mechanical, now, it’s all electronics... if you break it, it’s costly and people ended up passing the walking wounded cars from One to another.
Yes, it was many years ago, when I was young and not very experienced.
Cheers,
Louis
Cheers,
Louis
If I need factory links, do you know of an inexpensive source?
Brian
