2007 D3 A8 Parking Brake issue & Other electrical gremlins
Can someone tell me if I need a new parking brake motor or just a bad wire or recalibration. I pulled and pasted just the parking brake related stuff first, I will post entire scan below Thanks in advance!
I'm getting some other weird electrical codes too. The car has a newer Interstate battery. I read Ross Tech's wiki and it says get a new Audi battery. Not sure if that being coded wrong or not at all could be a problem
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0010
Revision: --H01--- Serial number: 4184960
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 23131317A7D3F0DF4C5-8076
1 Fault Found:
049448 - No Communications with Parking Brake Control Module
U0128 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250954 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:43
Freeze Frame:
RPM: 1184 /min
RPM: 1152 /min
RPM: 736 /min
(no units): 35.0
(no units): 35.0
Temperature: 78.0°C
T.B. Angle: 8.2°
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 221D1613B8C9F9D7473-8076
2 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
004 - No Signal/Communication
00003 - Control Module
014 - Defective
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000922
Shop #: WSC 01123 444 82775
VCID: 1F1B1FE78BBBD43F68D-804A
5 Faults Found:
02434 - Supply Voltage for Control Module for Left Channel
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11111001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
02432 - Supply Voltage for Left Parking Brake Motor (V282)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348EI067503500
Coding: 0000003
Shop #: WSC 12345 111 45725
VCID: 3333E3571733605FBC5-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000009121
Subsystem 3 - Serial number: 0118.05.060000000100010093ÿ
Subsystem 4 - Serial number: 010093ÿ
2 Faults Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 137
Mileage: 250888 km
Time Indication: 0
Date: 2018.06.11
Time: 13:17:04
02103 - Control Module 2 for Vehicle Electrical System (J520)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:08:56
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242id
Wednesday,13,June,2018,13:21:05:24716
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.1.2 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.1
www.Ross-Tech.com
VIN: WAULV44E07N000716 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAULV44E07N000716 Mileage: 251110km-156032miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Not registered 0011
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 1010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Not registered 0011
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: --H16--- Serial number: AUX3Z0F4793999
Coding: 01060009190F0120
Shop #: WSC 01013 444 54617
VCID: 20191C1BB6C5EBC7517-8074
1 Fault Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250955 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:55
Freeze Frame:
RPM: 725 /min
Load: 34.1 %
Speed: 2.0 km/h
Temperature: 99.0°C
Temperature: 46.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250954 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:43
Freeze Frame:
RPM: 1184 /min
RPM: 1152 /min
RPM: 736 /min
(no units): 35.0
(no units): 35.0
Temperature: 78.0°C
T.B. Angle: 8.2°
Coding: 0008597
2 Faults Found:
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F4793999
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58E974FBAE156307697-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 2411100BA2DDF7E735F-8070
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 137
Mileage: 250888 km
Time Indication: 0
Date: 2018.06.11
Time: 13:17:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:08:56
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000097286
Coding: 0037185
VCID: 1C6128EB9AADCF278DF-8048
1 Fault Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 11
Reset counter: 98
Mileage: 250634 km
Time Indication: 0
Date: 2018.06.01
Time: 09:16:13
Freeze Frame:
Temperature: 27.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 3635DA43044175779BB-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH12 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
Shop #: WSC 02399 823 56573
VCID: 2B03FB37C303389FF45-807E
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D8017305
Shop #: WSC 00000 000 00000
VCID: 2B03FB37CF03389FF45-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:41
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0005ZMC
Coding: 0532707
VCID: 26150A03D4E105F72BB-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36LY6
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ† 63
Subsystem 4 - Serial number: 000000ÿ† 63328RB40130ED29Kÿ† 63
Subsystem 5 - Serial number: 0ED29Kÿ† 63428RB40130ECFAYÿ† 63
Subsystem 6 - Serial number: 0ECFAYÿ† 63528RB40130ED00Bÿ† 63
Subsystem 7 - Serial number: 0ED00Bÿ† 63628RB40130ECFB.ÿ† 63
Subsystem 8 - Serial number: 0ECFB.ÿ† 63729RB401322E74Gÿ† 63
Subsystem 9 - Serial number: 22E74Gÿ† 63829RB401322E43Dÿ
Subsystem 10 - Serial number: 22E43Dÿ
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H02000 Serial number: 90055061130027
Coding: 0012241
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0520
Revision: D02 Serial number: AUDID3F4000229
Coding: 0048203
Shop #: WSC 11111 111 45799
VCID: 25170D0FA9E70EEF221-8070
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B064258167
Coding: F5D1DF7F30720E
Shop #: WSC 11111 111 45725
VCID: 6C81382B0A8DFFA7BDF-8038
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:39
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:44
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0019911
VCID: 2809043BDEF51387197-807C
2 Faults Found:
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 132
Mileage: 250581 km
Time Indication: 0
Date: 2018.05.31
Time: 15:02:27
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 39
Reset counter: 141
Mileage: 250585 km
Time Indication: 0
Date: 2018.05.31
Time: 15:25:14
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381EF067500440
VCID: 2E05F223FC114DB7D3B-807A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H04 0090
Serial number: 00000612400012
Coding: 0003477
VCID: 1D6725EF81B7C62F7A1-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040605190397
Coding: 0048702
VCID: 2A0DFE33C0F921970F3-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H02 0120
Revision: PROD_01 Serial number: 00000000000073
Coding: 0000026
VCID: 2C01F82BCA0D3FA7FDF-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000086006
Coding: 0010111
VCID: 1E6522E38CB1DD3763B-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T151305
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 7
Reset counter: 119
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:18:05
Freeze Frame:
Voltage: 13.46 V
Count: 236
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 78
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.20
Time: 22:53:14
Freeze Frame:
Voltage: 13.15 V
Count: 41
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396E/067537548
Coding: 0000002
VCID: 313FE95FED2F524FCE9-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009046
Shop #: WSC 00000 128 00289
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2605170302
Coding: 344530393135313035412056413032363035313730333032
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 140
Mileage: 250981 km
Time Indication: 0
Date: 2018.06.12
Time: 05:58:18
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900056505
Coding: 0232125
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 62
Reset counter: 0
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:42
Freeze Frame:
(no units): 0.0
Temperature: 19.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000605160081
Shop #: WSC 12336 024 394758
VCID: 3431E04B123D6767A5F-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J65108E
Coding: 1120602
VCID: 5CE168EBDA2D8F274DF-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720612805947
Coding: 0221208
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007563035
Coding: 0010900
End----------(Elapsed Time: 02:15, VBatt start/end: 13.6V/14.0V)-----------
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250955 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:55
Freeze Frame:
RPM: 725 /min
Load: 34.1 %
Speed: 2.0 km/h
Temperature: 99.0°C
Temperature: 46.0°C
Voltage: 13.970 V
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250954 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:43
Freeze Frame:
RPM: 1184 /min
RPM: 1152 /min
RPM: 736 /min
(no units): 35.0
(no units): 35.0
Temperature: 78.0°C
T.B. Angle: 8.2°
Coding: 0008597
2 Faults Found:
014 - Defective
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 137
Mileage: 250888 km
Time Indication: 0
Date: 2018.06.11
Time: 13:17:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:08:56
Coding: 0037185
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 98
Mileage: 250634 km
Time Indication: 0
Date: 2018.06.01
Time: 09:16:13
Freeze Frame:
Temperature: 27.0°C
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 020000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:41
Coding: 0532707
Coding: 0012241
Coding: 0048203
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:39
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:44
Coding: 0019911
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 132
Mileage: 250581 km
Time Indication: 0
Date: 2018.05.31
Time: 15:02:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 39
Reset counter: 141
Mileage: 250585 km
Time Indication: 0
Date: 2018.05.31
Time: 15:25:14
Coding: 4071530
Coding: 0003477
Coding: 0032364
Coding: 0048702
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 119
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:18:05
Freeze Frame:
Voltage: 13.46 V
Count: 236
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 78
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.20
Time: 22:53:14
Freeze Frame:
Voltage: 13.15 V
Count: 41
Coding: 0000018
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 140
Mileage: 250981 km
Time Indication: 0
Date: 2018.06.12
Time: 05:58:18
Coding: 0032364
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 62
Reset counter: 0
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:42
Freeze Frame:
(no units): 0.0
Temperature: 19.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1120602
Coding: 0032364
Coding: 0221208
Coding: 0010900
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250954 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:43
Freeze Frame:
RPM: 1184 /min
RPM: 1152 /min
RPM: 736 /min
(no units): 35.0
(no units): 35.0
Temperature: 78.0°C
T.B. Angle: 8.2°
Coding: 0008597
2 Faults Found:
014 - Defective
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 137
Mileage: 250888 km
Time Indication: 0
Date: 2018.06.11
Time: 13:17:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:08:56
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242id
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250955 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:55
Freeze Frame:
RPM: 725 /min
Load: 34.1 %
Speed: 2.0 km/h
Temperature: 99.0°C
Temperature: 46.0°C
Voltage: 13.970 V
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250954 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:43
Freeze Frame:
RPM: 1184 /min
RPM: 1152 /min
RPM: 736 /min
(no units): 35.0
(no units): 35.0
Temperature: 78.0°C
T.B. Angle: 8.2°
Coding: 0008597
2 Faults Found:
014 - Defective
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 137
Mileage: 250888 km
Time Indication: 0
Date: 2018.06.11
Time: 13:17:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:08:56
Coding: 0037185
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 98
Mileage: 250634 km
Time Indication: 0
Date: 2018.06.01
Time: 09:16:13
Freeze Frame:
Temperature: 27.0°C
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 020000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:41
Coding: 0532707
Coding: 0012241
Coding: 0048203
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:39
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:44
Coding: 0019911
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 132
Mileage: 250581 km
Time Indication: 0
Date: 2018.05.31
Time: 15:02:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 39
Reset counter: 141
Mileage: 250585 km
Time Indication: 0
Date: 2018.05.31
Time: 15:25:14
Coding: 4071530
Coding: 0003477
Coding: 0032364
Coding: 0048702
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 119
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:18:05
Freeze Frame:
Voltage: 13.46 V
Count: 236
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 78
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.20
Time: 22:53:14
Freeze Frame:
Voltage: 13.15 V
Count: 41
Coding: 0000018
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 140
Mileage: 250981 km
Time Indication: 0
Date: 2018.06.12
Time: 05:58:18
Coding: 0032364
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 62
Reset counter: 0
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:42
Freeze Frame:
(no units): 0.0
Temperature: 19.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1120602
Coding: 0032364
Coding: 0221208
Coding: 0010900
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250955 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:55
Freeze Frame:
RPM: 725 /min
Load: 34.1 %
Speed: 2.0 km/h
Temperature: 99.0°C
Temperature: 46.0°C
Voltage: 13.970 V
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 250954 km
Time Indication: 0
Date: 2018.06.11
Time: 16:52:43
Freeze Frame:
RPM: 1184 /min
RPM: 1152 /min
RPM: 736 /min
(no units): 35.0
(no units): 35.0
Temperature: 78.0°C
T.B. Angle: 8.2°
Coding: 0008597
2 Faults Found:
014 - Defective
Coding: 0410624
Component: ELV 1940
Coding: 4071520
Coding: 0000003
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 137
Mileage: 250888 km
Time Indication: 0
Date: 2018.06.11
Time: 13:17:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:08:56
Coding: 0037185
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 98
Mileage: 250634 km
Time Indication: 0
Date: 2018.06.01
Time: 09:16:13
Freeze Frame:
Temperature: 27.0°C
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Revision: 00000000
Coding: 020000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:41
Coding: 0532707
Coding: 0012241
Coding: 0048203
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:39
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 97
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:44
Coding: 0019911
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 132
Mileage: 250581 km
Time Indication: 0
Date: 2018.05.31
Time: 15:02:27
Freeze Frame:
Fault Priority: 3
Fault Frequency: 39
Reset counter: 141
Mileage: 250585 km
Time Indication: 0
Date: 2018.05.31
Time: 15:25:14
Coding: 4071530
Coding: 0003477
Coding: 0032364
Coding: 0048702
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 79
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 43
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 236
Mileage: 248032 km
Time Indication: 0
Date: 2018.01.26
Time: 14:50:40
Freeze Frame:
Voltage: 10.77 V
Count: 242
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 119
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:18:05
Freeze Frame:
Voltage: 13.46 V
Count: 236
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 78
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.20
Time: 22:53:14
Freeze Frame:
Voltage: 13.15 V
Count: 41
Coding: 0000018
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 140
Mileage: 250981 km
Time Indication: 0
Date: 2018.06.12
Time: 05:58:18
Coding: 0032364
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 137
Mileage: 250960 km
Time Indication: 0
Date: 2018.06.11
Time: 21:11:04
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 62
Reset counter: 0
Mileage: 250891 km
Time Indication: 0
Date: 2018.06.11
Time: 14:06:42
Freeze Frame:
(no units): 0.0
Temperature: 19.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1120602
Coding: 0032364
Coding: 0221208
Coding: 0010900
Clear all the codes first to get rid of intermittent stuff and then rescan parking brake module, post what you get. I have been fighting my parking brake errors for the last month and finally fixed it, should be able to help you out
Here's the parking brake scan, appreciate the help!
Saturday,23,June,2018,14:07:07:24716
VCDS Version: Release 18.2.1 (x64) Running on Windows 10 x64
Ross-Tech: Home
Control Module Part Number: 4E0 910 801 C HW: 4E0 907 801 A
Component and/or Version: EPB A32C0220 H02 0220
Software Coding: 0000922
Work Shop Code: WSC 01123 444 82775
5 Faults Found:
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00111001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 141
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Status: 11111100
Fault Priority: 1
Fault Frequency: 44
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 101
Mileage: 251104 km
Time Indication: 0
Date: 2018.06.13
Time: 14:22:16
Freeze Frame:
Voltage: 13.04 V
Count: 41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 141
Mileage: 251104 km
Time Indication: 0
Date: 2018.06.13
Time: 14:22:16
Freeze Frame:
Voltage: 13.04 V
Count: 236
02435 - Supply Voltage for Control Module for Right Channel
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 101
Mileage: 251104 km
Time Indication: 0
Date: 2018.06.13
Time: 13:47:37
Freeze Frame:
Voltage: 13.15 V
Count: 113
Ross-Tech: Home
5 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 141
Mileage: 249912 km
Time Indication: 0
Date: 2018.05.21
Time: 10:28:55
Freeze Frame:
Voltage: 13.66 V
Count: 112
Freeze Frame:
Fault Priority: 1
Fault Frequency: 44
Reset counter: 127
Mileage: 228840 km
Time Indication: 0
Date: 2016.05.17
Time: 06:57:34
Freeze Frame:
Voltage: 13.04 V
Count: 86
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 101
Mileage: 251104 km
Time Indication: 0
Date: 2018.06.13
Time: 14:22:16
Freeze Frame:
Voltage: 13.04 V
Count: 41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 141
Mileage: 251104 km
Time Indication: 0
Date: 2018.06.13
Time: 14:22:16
Freeze Frame:
Voltage: 13.04 V
Count: 236
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 101
Mileage: 251104 km
Time Indication: 0
Date: 2018.06.13
Time: 13:47:37
Freeze Frame:
Voltage: 13.15 V
Count: 113
I have similar code as yours. Still struggling as I only have VCP.
Try driving it for a while and check the code again.
Mine still have code but epb start working now. Had problem of abs and navi DVD issue that can not be cleared but both went away after driving a while.
