4 way climate problem..help please
hey there. 2006 a8 i have dual climate for front and back. even though i can change the temp. from the rear seats for the rear climate zone (max it will goto is 26 degrees celcius..ya im in canada)it wont take effect. if i set drivers side to "LO"(cold air) for example in the back rear left it will send cold air through the vents only..and same goes with the front/rear right. if i change to HI (hot in front) it will change to HOT. no matter if i have change temp in the back to LO or whatever.
any setting i need to change???
also the front will go upto 28 deg. celcius then to "HI" the max i can go @ the back is 26. any reason for that?
hope i didnt confuse anyone.
as i got 2 little ones and dont wanna freeze them even though its summer.
thank you all in advance.
Re: 4 way climate problem..help please
Use VAG diagnostics to test & troubleshoot the system. There are probably faults stored in memory that will help you.
http://www.ross-tech.com/index.html
or take it to a good shop that has the diagnotics package or a dealer.
BassicC7
A6 (C7 Platform) Discussion
10-19-2012 02:30 PM
