5.7 abs module
5.7 abs module
Ive got abs, esp, headlight range, and parking brake indicators at all times on my 04 A8L i checked the abs module harness and had some breaks in the wires (as ive heard most do) repaired them, tested for continuity all good. Cleared all codes via vcds, i went to all individual modules and cleared them, each came back immediately. It has a code for failed abs control module 014 in each of the 4 modules. Im assuming this means that the module is truly faulty, unless it would show this code for worn brake pads? Any advice? Also im new to this electromechanical parking brake system, the parking brakes work both sides, but i can only active the parking brake with the key completely off, and can only disengage them with the key on... is this normal operation? I dont have time right now to copy the scan here, but i will put it up tomorrow night so you all can see my black beauty's gremlins
Wednesday,06,March,2019,22:39:51:09961
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.1.2.0 (x64) HEX-V2 CB: 0.4502.4
Data version: 20190131 DS301.0
Ross-Tech: Home
VIN: WAUML44E94N014717 License Plate: MRY NLY
Mileage: 289710km-180017mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E94N014717 Mileage: 289710km-180017miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0CN528051
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F1BE1B43BBFB26FB19-804A
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0024629
Coding: 0000002
VCID: 2411EE5812D991B7ECB-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 211FE74C0DCB849F87D-8074
1 Fault Found:
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN528051
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58E98AA81E110557B03-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2313ED4417D7968F951-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346K-037507783
Coding: 0000103
Shop #: WSC 12345 111 45725
VCID: 2F3B11744B1F22EF019-807A
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000002633
Subsystem 3 - Serial number: 0111.03.060000000100010041˙
Subsystem 4 - Serial number: 010041˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000030175
Coding: 1085761
VCID: 5AED90A0601D1747867-800E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H01 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H01 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO11112003065A000000000069˙89
Subsystem 5 - Serial number: 000069˙898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO11112003065A00000000
Subsystem 7 - Serial number: 65A000000000070˙
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111111
VCID: 2A0D006070FD47C7D67-807E
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000030
Shop #: WSC 02311
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000501 Serial number: AUZ5ZBC1027012
Shop #: WSC 00000 000 00000
VCID: 196FCFAC259BDC5F4FD-804C
Address 0F: Digital Radio Labels: None
VCID: 55F7839C0D03383FAB5-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012241
VCID: 6597B35C5963A8BF3B5-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0080
Revision: D13 Serial number: AUDID3CN004207
Coding: 0016203
Shop #: WSC 58744 000 104857
VCID: 5CE196B86A29E97794B-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503A100CD4
Coding: FCFE7BDD1B2B04
Shop #: WSC 01115 444 59106
VCID: 2615F45064E563A7F2F-8072
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2517F35C19E368BFFB5-8070
1 Fault Found:
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 289717 km
Time Indication: 0
Date: 2019.03.06
Time: 22:37:52
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4071522
5 Faults Found:
01875 - Backrest/Head Adjustment Button (E332); Down
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 0 km
Time Indication: 0
Date: 2003.01.01
Time: 00:00:00
01453 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Forward
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 2
Fault Frequency: 13
Reset counter: 196
Mileage: 26080 km
Time Indication: 0
Date: 2019.02.05
Time: 05:11:29
01454 - Driver's Seat Fore/Aft and Height Adjust Switch (E61); Back
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 196
Mileage: 26080 km
Time Indication: 0
Date: 2019.02.05
Time: 05:11:29
01455 - Driver's Seat Switch for Seatback Adjust (E96); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 196
Mileage: 26080 km
Time Indication: 0
Date: 2019.02.13
Time: 10:50:27
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 5
Reset counter: 196
Mileage: 26876 km
Time Indication: 0
Date: 2019.02.23
Time: 00:15:16
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H42 0570
Revision: 00000000 Serial number: 355KQ037510941
VCID: 3537231CA943183F4B5-8060
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000425200031
Coding: 0003989
Shop #: WSC 01115 444 67090
VCID: 1D67DBBC31B3A07FA35-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EE59CB07C35FB67FAF-800A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040311070147
Coding: 0065150
VCID: 270BF95463EF7AAFC99-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
2 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 196
Mileage: 249233 km
Time Indication: 0
Date: 2013.11.03
Time: 18:33:24
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Priority: 3
Reset counter: 196
Mileage: 249233 km
Time Indication: 0
Date: 2013.11.03
Time: 18:33:24
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000567903
Coding: 0000016
VCID: 221DE84008CD9F879E7-8076
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000027151
Coding: 0010111
VCID: 1E65DCB03CB5BB67BAF-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T09HME
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
01316 - ABS Control Module
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Reset counter: 196
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 231
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Priority: 6
Fault Frequency: 40
Reset counter: 189
Mileage: 289416 km
Time Indication: 0
Date: 2019.03.02
Time: 12:29:04
Freeze Frame:
Voltage: 11.28 V
Count: 60
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 629DA840484DDF87DE7-8036
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 289720 km
Time Indication: 0
Date: 2019.03.06
Time: 22:38:45
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304DR057608477
Coding: 0000002
Shop #: WSC 01115 444 83893
VCID: 2019E24806C18D97883-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000004980755
Shop #: WSC 01115 444 56958
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1310240019
Coding: 303030393135313035414B56413031333130323430303139
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
VCID: 5DE79BBC7133E07FE35-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5F9BA1B47B3FF26FF19-800A
1 Fault Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 289717 km
Time Indication: 0
Date: 2019.03.06
Time: 22:39:04
Freeze Frame:
Speed: 0.0 km/h
Temperature: -2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
1 Fault Found:
02130 - Interior Door Lighting
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 289712 km
Time Indication: 0
Date: 2019.03.06
Time: 22:39:16
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3006246
Coding: 0000005
VCID: 6099A2484651CD97C83-513C
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000332100189
Coding: 0001208
End----------(Elapsed Time: 04:02, VBatt start/end: 12.0V/12.1V)-----------
Ross-Tech: Home
Coding: 0007773
Coding: 0000002
Coding: 0007597
1 Fault Found:
014 - Defective
Coding: 0263168
Component: ELV XXXX
Coding: 3940448
Coding: 0000103
Coding: 1085761
Coding: 0111111
Coding: 00000030
Shop #: WSC 02311
No Faults Found
Coding: 0530707
Coding: 0012241
Coding: 0016203
Coding: 0263168
Component: ELV XXXX
Coding: 0015510
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 289717 km
Time Indication: 0
Date: 2019.03.06
Time: 22:37:52
Coding: 4071522
5 Faults Found:
006 - Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 0 km
Time Indication: 0
Date: 2003.01.01
Time: 00:00:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 196
Mileage: 26080 km
Time Indication: 0
Date: 2019.02.05
Time: 05:11:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 196
Mileage: 26080 km
Time Indication: 0
Date: 2019.02.05
Time: 05:11:29
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 196
Mileage: 26080 km
Time Indication: 0
Date: 2019.02.13
Time: 10:50:27
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 196
Mileage: 26876 km
Time Indication: 0
Date: 2019.02.23
Time: 00:15:16
Coding: 0003989
Coding: 0028196
Coding: 0065150
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 196
Mileage: 249233 km
Time Indication: 0
Date: 2013.11.03
Time: 18:33:24
Freeze Frame:
Fault Priority: 3
Reset counter: 196
Mileage: 249233 km
Time Indication: 0
Date: 2013.11.03
Time: 18:33:24
Coding: 0000016
Coding: 0010111
Coding: 0028196
Revision: AV1C1010
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 196
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 231
Freeze Frame:
Fault Priority: 6
Fault Frequency: 40
Reset counter: 189
Mileage: 289416 km
Time Indication: 0
Date: 2019.03.02
Time: 12:29:04
Freeze Frame:
Voltage: 11.28 V
Count: 60
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 196
Mileage: 289720 km
Time Indication: 0
Date: 2019.03.06
Time: 22:38:45
Coding: 0000002
Coding: 0028196
Coding: 0212127
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 196
Mileage: 289717 km
Time Indication: 0
Date: 2019.03.06
Time: 22:39:04
Freeze Frame:
Speed: 0.0 km/h
Temperature: -2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028196
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 289712 km
Time Indication: 0
Date: 2019.03.06
Time: 22:39:16
Coding: 0000005
1 Fault Found:
Coding: 0001208
this is a known problem with our cars. Connection welding technology fails when it gets warm (it's very close to exhaust manifold). Sending it out to Cheap ABS is my recommendation also. That's the easy part of the process. Removing the module is somewhat more difficult. Send me a private message with your email and I will send a write up on how to remove it. I cannot attach a Word Document to a message and not sure how to post it in the main forum either, but I can attach it to an email.
Another ABS question - VAG cannot communicate with my ABS module, but I don't get a light and ABS...
DWP
01-23-2009 02:46 PM
odsagn
08-21-2007 07:19 PM
maggio
11-18-2006 05:46 PM
paul cormier
10-11-2006 07:17 AM
Just went out for a drive in 1" of snow and my RE730's - Result: ABS!ABS!ABS!ABS!ABS!ABS!ABS!ABS!ABS
Mark P
12-08-2000 11:02 AM
