A8 4.2 Rev bounce when coasting
My A8 has had this little annoying fault for the last few months.
When doing between 35-60mph and lifting off the throttle to coast, the car will bounce the revs like the TC lockup is unlocking and locking. In all other ways the car drives fine.
There are no engine or transmission codes, I have removed and cleaned the throttle body (this was very clean to begin with) and unplugged the maf to check it was working - it is and the maf has been cleaned.
When unplugging the maf, the little vac operated door in the intake closed and opened again when i plugged it back in. I could hear it, and the vac operated intake arms are working normally.
Anyone have any ideas of what to check?
Mike
Mike
Since you have already done the throttle body, I am guessing the torque converter. That turned out to be the culprit on my old 2005 4.2. The problem started when the car had approximately 125k miles on the odometer.
It doesn't seem to be the torque converter. It locks up normally at other times and on the highway no problem.
My car has 139,000 miles on it.
I am thinking it could be a vacuum leak perhaps but I do not know the system well enough,
Still getting the 17549 - Load Calculation Cross Check: Implausible Value P1141 - 35-10 - - - Interm
Kris Hansen
06-24-2008 05:41 PM
islingtonaudi
Audi 100 / A6 (C4 Platform)
06-12-2007 06:45 AM
lolyf
06-05-2006 08:01 PM
bretto
03-13-2003 05:23 AM
Kris Hansen
09-26-2002 11:04 AM
